Size: 10.75 x 21
Design Span (L): 39.33 ft.
Clear Span: 38.67 ft.
Total Span: 40.00 ft.
Bearing (lb): 8 in.
Live Load: 500 plf
Dead Load: 30 plf
Selfweight: 2081.8 lbs
Dist. Selfweight: 52.93 plf
Total Weight: 2117.1 lbs
Lateral Support: 10' o/c
CV Volume Factor 0.825b - - - - -
Beam Design 2023A212
5/5/2023 1
b = 10.750 in.
d = 21.000 in.
A = 10.750 x 21.000 = 225.75 in.2
Sx = (10.750)(21.000)2/6 = 790.13 in.3
Sy = (10.750)2(21.000)/6 = 404.47 in.3
Ix = (10.750)(21.000)3/12 = 8296.31 in.4
Iy = (10.750)3(21.000)/12 = 2174.02 in.4
5/5/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [225.75 x (472.00 + 8)] x (12 in./ft.)3 = 62.71 ft3
Volumespan = N[A x L] = 1 x [225.75 x 472.00] x (12 in./ft.)3 = 61.66 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 62.71 = 2117.1 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 61.66 = 2081.8 lbs
Distributed Self Weight (ws) = = 52.93 plf
500 plf
30 plf
  ws = 52.93 plf
39.33 ft.
38.67 ft.
40.00 ft.
11658.46 lbs
11658.46 lbs
5/5/2023 3
lu = Unbraced Length = 10 ft.
lu/d = = 5.71
le = 2.06lu = 2.06(120.0) = 247.20 in. = 20.60 ft.  (NDS Table 3.3.3)
Rb = = 6.70
 Rb = 6.70 < 50   ➜  OK
5/5/2023 4
FbE = = 22706.46 psi
CL =   = 0.993
CV = = 0.825
CV = 0.825 < CL = 0.993
Fbx' = (2400)(1.15)(1)(1)(0.825) = 2276.0 psi
fb = = 1712.1 psi
 fb = 1712.1 psi < Fbx' = 2276.0 psi  (CSI = 0.75)   ➜  OK
fv* = = 69.40 psi
5/5/2023 5
 fv* = 69.40 psi < Fvx' = 304.75 psi  (CSI = 0.23)   ➜  OK
fv = = 76.17 psi
 fv = 76.17 psi < Fvx' = 304.75 psi  (CSI = 0.25)   ➜  OK
ΔLL = = 1.80 in.
(L/d)LL = 472.00 / 1.80 = 262
 ΔLL = 1.80 in = L/262 < L/240   ➜  OK
ΔTL = = 2.10 in.
(L/d)TL = 472.00 / 2.10 = 225
 ΔTL = 2.10 in = L/225 < L/180   ➜  OK
5/5/2023 6
Ab = b x lb = 10.75 x 8 = 86.00 in2
fc⊥ = = 135.6 psi
 fc⊥ = 135.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.21)   ➜  OK
5/5/2023 7
