Size: 12.25 x 42
Design Span (L): 60.50 ft.
Clear Span: 60.00 ft.
Total Span: 61.00 ft.
Live Load: 920 plf
Dead Load: 63 plf
Selfweight: 7297.9 lbs
Dist. Selfweight: 120.63 plf
Total Weight: 7358.2 lbs
Lateral Support: 8' o/c
CV Volume Factor 0.727b - - - - -
Beam Design 2023A210
5/5/2023 1
b = 12.250 in.
d = 42.000 in.
A = 12.250 x 42.000 = 514.50 in.2
Sx = (12.250)(42.000)2/6 = 3601.50 in.3
Sy = (12.250)2(42.000)/6 = 1050.44 in.3
Ix = (12.250)(42.000)3/12 = 75631.50 in.4
Iy = (12.250)3(42.000)/12 = 6433.93 in.4
5/5/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [514.50 x (726.00 + 6)] x (12 in./ft.)3 = 217.95 ft3
Volumespan = N[A x L] = 1 x [514.50 x 726.00] x (12 in./ft.)3 = 216.16 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 217.95 = 7358.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 216.16 = 7297.9 lbs
Distributed Self Weight (ws) = = 120.63 plf
920 plf
63 plf
  ws = 120.63 plf
60.50 ft.
60.00 ft.
61.00 ft.
33660.59 lbs
33660.59 lbs
5/5/2023 3
lu = Unbraced Length = 8 ft.
lu/d = = 2.29
le = 2.06lu = 2.06(96.0) = 197.76 in. = 16.48 ft.  (NDS Table 3.3.3)
Rb = = 7.44
 Rb = 7.44 < 50   ➜  OK
5/5/2023 4
FbE = = 18428.27 psi
CL =   = 0.991
CV = = 0.727
CV = 0.727 < CL = 0.991
Fbx' = (2400)(1.15)(1)(1)(0.727) = 2007.7 psi
fb = = 1682.4 psi
 fb = 1682.4 psi < Fbx' = 2007.7 psi  (CSI = 0.84)   ➜  OK
fv* = = 86.07 psi
5/5/2023 5
 fv* = 86.07 psi < Fvx' = 304.75 psi  (CSI = 0.28)   ➜  OK
fv = = 97.33 psi
 fv = 97.33 psi < Fvx' = 304.75 psi  (CSI = 0.32)   ➜  OK
ΔLL = = 2.04 in.
(L/d)LL = 726.00 / 2.04 = 356
 ΔLL = 2.04 in = L/356 > L/360   ➜  NG
ΔTL = = 2.44 in.
(L/d)TL = 726.00 / 2.44 = 297
 ΔTL = 2.44 in = L/297 < L/240   ➜  OK
5/5/2023 6
Ab = b x lb = 12.25 x 6 = 73.50 in2
fc⊥ = = 458.0 psi
 fc⊥ = 458.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.70)   ➜  OK
5/5/2023 7
