Size: 12.25 x 34.5
Design Span (L): 60.50 ft.
Clear Span: 60.00 ft.
Total Span: 61.00 ft.
Live Load: 550 plf
Dead Load: 45 plf
Selfweight: 5994.7 lbs
Dist. Selfweight: 99.09 plf
Total Weight: 6044.2 lbs
Lateral Support: 8' o/c
CV Volume Factor 0.742b - - - - -
Beam Design 2023A209
5/4/2023 1
b = 12.250 in.
d = 34.500 in.
A = 12.250 x 34.500 = 422.63 in.2
Sx = (12.250)(34.500)2/6 = 2430.09 in.3
Sy = (12.250)2(34.500)/6 = 862.86 in.3
Ix = (12.250)(34.500)3/12 = 41919.12 in.4
Iy = (12.250)3(34.500)/12 = 5285.01 in.4
5/4/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [422.63 x (726.00 + 6)] x (12 in./ft.)3 = 179.03 ft3
Volumespan = N[A x L] = 1 x [422.63 x 726.00] x (12 in./ft.)3 = 177.56 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 179.03 = 6044.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 177.56 = 5994.7 lbs
Distributed Self Weight (ws) = = 99.09 plf
550 plf
45 plf
  ws = 99.09 plf
60.50 ft.
60.00 ft.
61.00 ft.
21169.61 lbs
21169.61 lbs
5/4/2023 3
lu = Unbraced Length = 8 ft.
lu/d = = 2.78
le = 2.06lu = 2.06(96.0) = 197.76 in. = 16.48 ft.  (NDS Table 3.3.3)
Rb = = 6.74
 Rb = 6.74 < 50   ➜  OK
5/4/2023 4
FbE = = 22434.42 psi
CL =   = 0.993
CV = = 0.742
CV = 0.742 < CL = 0.993
Fbx' = (2400)(1.15)(1)(1)(0.742) = 2047.6 psi
fb = = 1568.2 psi
 fb = 1568.2 psi < Fbx' = 2047.6 psi  (CSI = 0.77)   ➜  OK
fv* = = 67.44 psi
5/4/2023 5
 fv* = 67.44 psi < Fvx' = 304.75 psi  (CSI = 0.22)   ➜  OK
fv = = 74.52 psi
 fv = 74.52 psi < Fvx' = 304.75 psi  (CSI = 0.24)   ➜  OK
ΔLL = = 2.20 in.
(L/d)LL = 726.00 / 2.20 = 330
 ΔLL = 2.20 in = L/330 > L/360   ➜  NG
ΔTL = = 2.77 in.
(L/d)TL = 726.00 / 2.77 = 262
 ΔTL = 2.77 in = L/262 < L/240   ➜  OK
5/4/2023 6
Ab = b x lb = 12.25 x 6 = 73.50 in2
fc⊥ = = 288.0 psi
 fc⊥ = 288.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.44)   ➜  OK
5/4/2023 7
