Grade: SP SS
Design Span (L): 12.88 ft.
Clear Span: 12.75 ft.
Total Span: 13.00 ft.
Bearing (lb): 1.5 in.
Live Load: 127.5 plf
Dead Load: 0 plf
Selfweight: 72.6 lbs
Dist. Selfweight: 5.64 plf
Total Weight: 73.3 lbs
Beam Design 2023A204
5/3/2023 1
SP SS 1950 1350 175 565 1700 1800000 660000 0.55
5/3/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (154.50 + 1.5)] x (12 in./ft.)3 = 1.96 ft3
Volumespan = N[A x L] = 2 x [10.88 x 154.50] x (12 in./ft.)3 = 1.94 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.96 = 73.3 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.94 = 72.6 lbs
127.5 plf
0 plf
ws = 5.64 plf
12.88 ft.
12.75 ft.
13.00 ft.
865.40 lbs
865.40 lbs
5/3/2023 3
Fbx' = (1950)(1.00)(1)(1)(1)(1)(1)(1) = 1950.0 psi
fb = = 1259.6 psi
 fb = 1259.6 psi < Fbx' = 1950.0 psi  (CSI = 0.65)   ➜  OK
5/3/2023 4
fv* = = 53.56 psi
 fv* = 53.56 psi < Fvx' = 175.00 psi  (CSI = 0.31)   ➜  OK
fv = = 59.11 psi
 fv = 59.11 psi < Fvx' = 175.00 psi  (CSI = 0.34)   ➜  OK
5/3/2023 5
ΔLL = = 0.46 in.
(L/d)LL = 154.50 / 0.46 = 336
 ΔLL = 0.46 in = L/336 > L/360   ➜  NG
ΔTL = = 0.48 in.
(L/d)TL = 154.50 / 0.48 = 322
 ΔTL = 0.48 in = L/322 < L/240   ➜  OK
fc⊥ = = 192.3 psi
 fc⊥ = 192.3 psi < Fc⊥x' = 565.00 psi  (CSI = 0.34)   ➜  OK
5/3/2023 6
