Grade: 24F-V3 1.8E SP/SP
Size: 2.5 x 11
Design Span (L): 22.25 ft.
Clear Span: 22.00 ft.
Total Span: 22.50 ft.
Quantity (N): 5
Live Load: 207 plf
Dead Load: 62 plf
Selfweight: 783.7 lbs
Dist. Selfweight: 35.22 plf
Total Weight: 792.5 lbs
Defl. Limits: 480|360
Beam Design 2023A199
4/22/2023 1
b = 2.500 in.
d = 11.000 in.
A = 2.500 x 11.000 = 27.50 in.2
Sx = (2.500)(11.000)2/6 = 50.42 in.3
Sy = (2.500)2(11.000)/6 = 11.46 in.3
Ix = (2.500)(11.000)3/12 = 277.29 in.4
Iy = (2.500)3(11.000)/12 = 14.32 in.4
4/22/2023 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 5 x [27.50 x (267.00 + 3)] x (12 in./ft.)3 = 21.48 ft3
Volumespan = N[A x L] = 5 x [27.50 x 267.00] x (12 in./ft.)3 = 21.25 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 21.48 = 792.5 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 21.25 = 783.7 lbs
Distributed Self Weight (ws) = = 35.22 plf
207 plf
62 plf
  ws = 35.22 plf
22.25 ft.
22.00 ft.
22.50 ft.
3422.52 lbs
3422.52 lbs
4/22/2023 3
fb = = 896.2 psi
 fb = 896.2 psi < Fbx' = 2400.0 psi  (CSI = 0.37)   ➜  OK
4/22/2023 4
fv* = = 33.88 psi
 fv* = 33.88 psi < Fvx' = 300.00 psi  (CSI = 0.11)   ➜  OK
fv = = 36.92 psi
 fv = 36.92 psi < Fvx' = 300.00 psi  (CSI = 0.12)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
4/22/2023 5
ΔLL = = 0.46 in.
(L/d)LL = 267.00 / 0.46 = 584
 ΔLL = 0.46 in = L/584 < L/480   ➜  OK
ΔTL = = 0.67 in.
(L/d)TL = 267.00 / 0.67 = 397
 ΔTL = 0.67 in = L/397 < L/360   ➜  OK
fc⊥ = = 91.3 psi
 fc⊥ = 91.3 psi < Fc⊥x' = 740.00 psi  (CSI = 0.12)   ➜  OK
4/22/2023 6
