Size: 8.75 x 30
Design Span (L): 39.33 ft.
Clear Span: 38.67 ft.
Total Span: 40.00 ft.
Bearing (lb): 8 in.
Live Load: 1950 plf
Dead Load: 125 plf
Selfweight: 4841.4 lbs
Dist. Selfweight: 123.09 plf
Total Weight: 4923.5 lbs
Lateral Support: 10' o/c
CV Volume Factor 0.812b - - - - -
Beam Design 2023A196
4/20/2023 1
b = 8.750 in.
d = 30.000 in.
A = 8.750 x 30.000 = 262.50 in.2
Sx = (8.750)(30.000)2/6 = 1312.50 in.3
Sy = (8.750)2(30.000)/6 = 382.81 in.3
Ix = (8.750)(30.000)3/12 = 19687.50 in.4
Iy = (8.750)3(30.000)/12 = 1674.80 in.4
4/20/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [262.50 x (472.00 + 8)] x (12 in./ft.)3 = 145.83 ft3
Volumespan = N[A x L] = 2 x [262.50 x 472.00] x (12 in./ft.)3 = 143.40 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 145.83 = 4923.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 143.40 = 4841.4 lbs
Distributed Self Weight (ws) = = 123.09 plf
1950 plf
125 plf
  ws = 123.09 plf
39.33 ft.
38.67 ft.
40.00 ft.
43961.39 lbs
43961.39 lbs
4/20/2023 3
lu = Unbraced Length = 10 ft.
lu/d = = 4.00
le = 2.06lu = 2.06(120.0) = 247.20 in. = 20.60 ft.  (NDS Table 3.3.3)
Rb = = 4.92
 Rb = 4.92 < 50   ➜  OK
4/20/2023 4
FbE = = 42121.76 psi
CL =   = 0.997
CV = = 0.812
CV = 0.812 < CL = 0.997
Fbx' = (2400)(1.15)(1)(1)(0.812) = 2242.0 psi
fb = = 1943.2 psi
 fb = 1943.2 psi < Fbx' = 2242.0 psi  (CSI = 0.87)   ➜  OK
fv* = = 107.81 psi
4/20/2023 5
 fv* = 107.81 psi < Fvx' = 304.75 psi  (CSI = 0.35)   ➜  OK
fv = = 123.51 psi
 fv = 123.51 psi < Fvx' = 304.75 psi  (CSI = 0.41)   ➜  OK
ΔLL = = 1.48 in.
(L/d)LL = 472.00 / 1.48 = 319
 ΔLL = 1.48 in = L/319 < L/240   ➜  OK
ΔTL = = 1.67 in.
(L/d)TL = 472.00 / 1.67 = 283
 ΔTL = 1.67 in = L/283 < L/180   ➜  OK
4/20/2023 6
Ab = b x lb = 8.75 x 8 = 70.00 in2
fc⊥ = = 314.0 psi
 fc⊥ = 314.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.48)   ➜  OK
4/20/2023 7
