Size: 6.75 x 30
Design Span (L): 39.33 ft.
Clear Span: 38.67 ft.
Total Span: 40.00 ft.
Bearing (lb): 8 in.
Live Load: 1950 plf
Dead Load: 125 plf
Selfweight: 3734.8 lbs
Dist. Selfweight: 94.95 plf
Total Weight: 3798.1 lbs
Lateral Support: 10' o/c
CV Volume Factor 0.834b - - - - -
Beam Design 2023A195
4/20/2023 1
b = 6.750 in.
d = 30.000 in.
A = 6.750 x 30.000 = 202.50 in.2
Sx = (6.750)(30.000)2/6 = 1012.50 in.3
Sy = (6.750)2(30.000)/6 = 227.81 in.3
Ix = (6.750)(30.000)3/12 = 15187.50 in.4
Iy = (6.750)3(30.000)/12 = 768.87 in.4
4/20/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [202.50 x (472.00 + 8)] x (12 in./ft.)3 = 112.50 ft3
Volumespan = N[A x L] = 2 x [202.50 x 472.00] x (12 in./ft.)3 = 110.62 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 112.50 = 3798.1 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 110.62 = 3734.8 lbs
Distributed Self Weight (ws) = = 94.95 plf
1950 plf
125 plf
  ws = 94.95 plf
39.33 ft.
38.67 ft.
40.00 ft.
43398.71 lbs
43398.71 lbs
4/20/2023 3
lu = Unbraced Length = 10 ft.
lu/d = = 4.00
le = 2.06lu = 2.06(120.0) = 247.20 in. = 20.60 ft.  (NDS Table 3.3.3)
Rb = = 6.38
 Rb = 6.38 < 50   ➜  OK
4/20/2023 4
FbE = = 25066.75 psi
CL =   = 0.994
CV = = 0.834
CV = 0.834 < CL = 0.994
Fbx' = (2400)(1.15)(1)(1)(0.834) = 2300.9 psi
fb = = 2486.7 psi
 fb = 2486.7 psi > Fbx' = 2300.9 psi  (CSI = 1.08)   ➜  NG
fv* = = 137.96 psi
4/20/2023 5
 fv* = 137.96 psi < Fvx' = 304.75 psi  (CSI = 0.45)   ➜  OK
fv = = 158.06 psi
 fv = 158.06 psi < Fvx' = 304.75 psi  (CSI = 0.52)   ➜  OK
ΔLL = = 1.92 in.
(L/d)LL = 472.00 / 1.92 = 246
 ΔLL = 1.92 in = L/246 < L/240   ➜  OK
ΔTL = = 2.14 in.
(L/d)TL = 472.00 / 2.14 = 221
 ΔTL = 2.14 in = L/221 < L/180   ➜  OK
4/20/2023 6
Ab = b x lb = 6.75 x 8 = 54.00 in2
fc⊥ = = 401.8 psi
 fc⊥ = 401.8 psi < Fc⊥x' = 650.00 psi  (CSI = 0.62)   ➜  OK
4/20/2023 7
