Size: 3.5 x 16.5
Design Span (L): 31.75 ft.
Clear Span: 31.50 ft.
Total Span: 32.00 ft.
Live Load: 325 plf
Dead Load: 45 plf
Selfweight: 859.8 lbs
Dist. Selfweight: 27.08 plf
Total Weight: 866.5 lbs
CV Volume Factor 0.966b - - - - -
Beam Design 2023A194
4/20/2023 1
d = 16.500 in.
A = 3.500 x 16.500 = 57.75 in.2
Sx = (3.500)(16.500)2/6 = 158.81 in.3
Sy = (3.500)2(16.500)/6 = 33.69 in.3
Ix = (3.500)(16.500)3/12 = 1310.20 in.4
Iy = (3.500)3(16.500)/12 = 58.95 in.4
4/20/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [57.75 x (381.00 + 3)] x (12 in./ft.)3 = 25.67 ft3
Volumespan = N[A x L] = 2 x [57.75 x 381.00] x (12 in./ft.)3 = 25.47 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 25.67 = 866.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 25.47 = 859.8 lbs
Distributed Self Weight (ws) = = 27.08 plf
325 plf
45 plf
  ws = 27.08 plf
31.75 ft.
31.50 ft.
32.00 ft.
6353.27 lbs
6353.27 lbs
4/20/2023 3
lu = Unbraced Length = 6 ft.
lu/d = = 4.36
le = 2.06lu = 2.06(72.0) = 148.32 in. = 12.36 ft.  (NDS Table 3.3.3)
Rb = = 7.07
 Rb = 7.07 < 50   ➜  OK
4/20/2023 4
FbE = = 20422.67 psi
CL =   = 0.992
CV = = 0.966
CV = 0.966 < CL = 0.992
Fbx' = (2400)(1.15)(1)(1)(0.966) = 2664.9 psi
fb = = 1890.3 psi
 fb = 1890.3 psi < Fbx' = 2664.9 psi  (CSI = 0.71)   ➜  OK
fv* = = 74.77 psi
4/20/2023 5
 fv* = 74.77 psi < Fvx' = 304.75 psi  (CSI = 0.25)   ➜  OK
fv = = 81.87 psi
 fv = 81.87 psi < Fvx' = 304.75 psi  (CSI = 0.27)   ➜  OK
ΔLL = = 1.58 in.
(L/d)LL = 381.00 / 1.58 = 242
 ΔLL = 1.58 in = L/242 < L/240   ➜  OK
ΔTL = = 1.92 in.
(L/d)TL = 381.00 / 1.92 = 198
 ΔTL = 1.92 in = L/198 < L/180   ➜  OK
4/20/2023 6
fc⊥ = = 302.5 psi
 fc⊥ = 302.5 psi < Fc⊥x' = 650.00 psi  (CSI = 0.47)   ➜  OK
4/20/2023 7
