Size: 5.5 x 16.5
Design Span (L): 19.50 ft.
Clear Span: 19.00 ft.
Total Span: 20.00 ft.
Live Load: 975 plf
Dead Load: 45 plf
Selfweight: 414.9 lbs
Dist. Selfweight: 21.28 plf
Total Weight: 425.5 lbs
CL Beam Stability Factor 0.986 - - - - -
CV Volume Factor 0.969b - - - - -
Beam Design 2023A192
4/20/2023 1
d = 16.500 in.
4/20/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [90.75 x (234.00 + 6)] x (12 in./ft.)3 = 12.60 ft3
Volumespan = N[A x L] = 1 x [90.75 x 234.00] x (12 in./ft.)3 = 12.29 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 12.60 = 425.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 12.29 = 414.9 lbs
975 plf
45 plf
  ws = 21.28 plf
19.50 ft.
19.00 ft.
10412.77 lbs
10412.77 lbs
4/20/2023 3
lu = Unbraced Length = 6 ft.
lu/d = = 4.36
le = 2.06lu = 2.06(72.0) = 148.32 in. = 12.36 ft.  (NDS Table 3.3.3)
Rb = = 8.99
 Rb = 8.99 < 50   ➜  OK
4/20/2023 4
FbE = = 12607.87 psi
CL =   = 0.986
CV = = 0.969
CV = 0.969 < CL = 0.986
Fbx' = (2400)(1.15)(1)(1)(0.969) = 2674.4 psi
fb = = 2379.8 psi
 fb = 2379.8 psi < Fbx' = 2674.4 psi  (CSI = 0.89)   ➜  OK
fv* = = 144.14 psi
4/20/2023 5
 fv* = 144.14 psi < Fvx' = 304.75 psi  (CSI = 0.47)   ➜  OK
fv = = 167.81 psi
 fv = 167.81 psi < Fvx' = 304.75 psi  (CSI = 0.55)   ➜  OK
ΔLL = = 0.86 in.
(L/d)LL = 234.00 / 0.86 = 273
 ΔLL = 0.86 in = L/273 < L/240   ➜  OK
ΔTL = = 0.91 in.
(L/d)TL = 234.00 / 0.91 = 256
 ΔTL = 0.91 in = L/256 < L/180   ➜  OK
4/20/2023 6
fc⊥ = = 315.5 psi
 fc⊥ = 315.5 psi < Fc⊥x' = 650.00 psi  (CSI = 0.49)   ➜  OK
4/20/2023 7
