Beam Design - Sutter Management
Grade: DF SS
Design Span (L): 11.67 ft.
Clear Span: 11.33 ft.
Bearing (lb): 4 in.
Live Load: 352 plf
Dead Load: 80 plf
Selfweight: 115.4 lbs
Dist. Selfweight: 9.89 plf
Total Weight: 118.6 lbs
Beam Design Clint Sutter Kelvington 2023A19
2/1/2023 1
2/1/2023 2
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (140.00 + 4)] x (12 in./ft.)3 = 3.47 ft3
Volumespan = N[A x L] = 3 x [13.88 x 140.00] x (12 in./ft.)3 = 3.37 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.47 = 118.6 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.37 = 115.4 lbs
352 plf
80 plf
ws = 9.89 plf
11.67 ft.
11.33 ft.
2651.40 lbs
2651.40 lbs
2/1/2023 3
Fbx' = (1500)(1.15)(1)(1)(1)(1.1)(1)(1) = 1897.5 psi
fb = = 1406.0 psi
 fb = 1406.0 psi < Fbx' = 1897.5 psi  (CSI = 0.74)   ➜  OK
2/1/2023 4
fv* = = 80.62 psi
 fv* = 80.62 psi < Fvx' = 207.00 psi  (CSI = 0.39)   ➜  OK
fv = = 92.89 psi
 fv = 92.89 psi < Fvx' = 207.00 psi  (CSI = 0.45)   ➜  OK
2/1/2023 5
ΔLL = = 0.26 in.
(L/d)LL = 140.00 / 0.26 = 538
 ΔLL = 0.26 in = L/538 < L/360   ➜  OK
ΔTL = = 0.33 in.
(L/d)TL = 140.00 / 0.33 = 429
 ΔTL = 0.33 in = L/429 < L/240   ➜  OK
fc⊥ = = 147.3 psi
 fc⊥ = 147.3 psi < Fc⊥x' = 625.00 psi  (CSI = 0.24)   ➜  OK
2/1/2023 6
