Beam Design - Floyd Family Residence - Kitchen Beam
Grade: 24F-V8 1.8E SP/SP
Size: 3.5 x 11
Quantity (N): 4
Selfweight: 463.6 lbs
Dist. Selfweight: 39.45 plf
Total Weight: 473.4 lbs
Beam Design Justin Showghi 2023.04.19
4/19/2023 1
d = 11.000 in.
A = 3.500 x 11.000 = 38.50 in.2
Sx = (3.500)(11.000)2/6 = 70.58 in.3
Sy = (3.500)2(11.000)/6 = 22.46 in.3
Ix = (3.500)(11.000)3/12 = 388.21 in.4
Iy = (3.500)3(11.000)/12 = 39.30 in.4
4/19/2023 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 4 x [38.50 x (141.00 + 3)] x (12 in./ft.)3 = 12.83 ft3
Volumespan = N[A x L] = 4 x [38.50 x 141.00] x (12 in./ft.)3 = 12.57 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 12.83 = 473.4 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 12.57 = 463.6 lbs
Distributed Self Weight (ws) = = 39.45 plf
  ws = 39.45 plf
1286.71 lbs
1286.71 lbs
4/19/2023 3
fb = = 157.3 psi
 fb = 157.3 psi < Fbx' = 2760.0 psi  (CSI = 0.06)   ➜  OK
4/19/2023 4
fv* = = 10.36 psi
 fv* = 10.36 psi < Fvx' = 345.00 psi  (CSI = 0.03)   ➜  OK
fv = = 12.27 psi
 fv = 12.27 psi < Fvx' = 345.00 psi  (CSI = 0.04)   ➜  OK
4/19/2023 5
ΔLL = = 0.02 in.
(L/d)LL = 141.00 / 0.02 = 9189
 ΔLL = 0.02 in = L/9189 < L/360   ➜  OK
ΔTL = = 0.03 in.
(L/d)TL = 141.00 / 0.03 = 4285
 ΔTL = 0.03 in = L/4285 < L/240   ➜  OK
fc⊥ = = 30.6 psi
 fc⊥ = 30.6 psi < Fc⊥x' = 740.00 psi  (CSI = 0.04)   ➜  OK
4/19/2023 6
