Design Span (L): 15.58 ft.
Clear Span: 15.17 ft.
Total Span: 16.00 ft.
Bearing (lb): 5 in.
Selfweight: 62.5 lbs
Dist. Selfweight: 4.01 plf
Total Weight: 64.1 lbs
Beam Design 2023A185
4/19/2023 1
4/19/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (187.00 + 5)] x (12 in./ft.)3 = 1.87 ft3
Volumespan = N[A x L] = 1 x [16.88 x 187.00] x (12 in./ft.)3 = 1.83 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.87 = 64.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.83 = 62.5 lbs
ws = 4.01 plf
15.58 ft.
15.17 ft.
1432.04 lbs
1432.04 lbs
4/19/2023 3
fb = = 2060.7 psi
 fb = 2060.7 psi > Fbx' = 1035.0 psi  (CSI = 1.99)   ➜  NG
4/19/2023 4
fv* = = 109.06 psi
 fv* = 109.06 psi < Fvx' = 207.00 psi  (CSI = 0.53)   ➜  OK
fv = = 123.98 psi
 fv = 123.98 psi < Fvx' = 207.00 psi  (CSI = 0.60)   ➜  OK
4/19/2023 5
ΔLL = = 0.47 in.
(L/d)LL = 187.00 / 0.47 = 401
 ΔLL = 0.47 in = L/401 < L/360   ➜  OK
ΔTL = = 0.83 in.
(L/d)TL = 187.00 / 0.83 = 224
 ΔTL = 0.83 in = L/224 > L/240   ➜  NG
Ab = b x lb = 1.5 x 5 = 7.50 in2
fc⊥ = = 190.9 psi
 fc⊥ = 190.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.31)   ➜  OK
4/19/2023 6
