Beam Design - Long Side Floor Joists
Grade: SP DSS
Design Span (L): 12.21 ft.
Clear Span: 11.92 ft.
Total Span: 12.50 ft.
Bearing (lb): 3.5 in.
Live Load: 140 plf
Dead Load: 50 plf
Selfweight: 68.8 lbs
Dist. Selfweight: 5.64 plf
Total Weight: 70.5 lbs
Notes: LONG SPAN
Beam Design Jeff Chodrow Apex NC 2023A184
4/18/2023 1
SP DSS 2200 1550 175 660 1850 1900000 690000 0.55
4/18/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (146.50 + 3.5)] x (12 in./ft.)3 = 1.89 ft3
Volumespan = N[A x L] = 2 x [10.88 x 146.50] x (12 in./ft.)3 = 1.84 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.89 = 70.5 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.84 = 68.8 lbs
140 plf
50 plf
ws = 5.64 plf
12.21 ft.
11.92 ft.
12.50 ft.
1222.71 lbs
1222.71 lbs
4/18/2023 3
Fbx' = (2200)(1.15)(1)(1)(1)(1)(1)(1) = 2530.0 psi
fb = = 1664.1 psi
 fb = 1664.1 psi < Fbx' = 2530.0 psi  (CSI = 0.66)   ➜  OK
4/18/2023 4
fv* = = 74.21 psi
 fv* = 74.21 psi < Fvx' = 201.25 psi  (CSI = 0.37)   ➜  OK
fv = = 82.36 psi
 fv = 82.36 psi < Fvx' = 201.25 psi  (CSI = 0.41)   ➜  OK
4/18/2023 5
ΔLL = = 0.39 in.
(L/d)LL = 146.50 / 0.39 = 379
 ΔLL = 0.39 in = L/379 < L/360   ➜  OK
ΔTL = = 0.54 in.
(L/d)TL = 146.50 / 0.54 = 271
 ΔTL = 0.54 in = L/271 < L/240   ➜  OK
fc⊥ = = 116.4 psi
 fc⊥ = 116.4 psi < Fc⊥x' = 660.00 psi  (CSI = 0.18)   ➜  OK
4/18/2023 6
