Beam Design - Sutter Management
Size: 10.75 x 30
Design Span (L): 51.00 ft.
Clear Span: 50.00 ft.
Total Span: 52.00 ft.
Bearing (lb): 12 in.
Live Load: 528 plf
Dead Load: 120 plf
Selfweight: 3856.2 lbs
Dist. Selfweight: 75.61 plf
Total Weight: 3931.8 lbs
CV Volume Factor 0.775b - - - - -
Beam Design Clint Sutter Kelvington 2023A18
2/1/2023 1
b = 10.750 in.
d = 30.000 in.
A = 10.750 x 30.000 = 322.50 in.2
Sx = (10.750)(30.000)2/6 = 1612.50 in.3
Sy = (10.750)2(30.000)/6 = 577.81 in.3
Ix = (10.750)(30.000)3/12 = 24187.50 in.4
Iy = (10.750)3(30.000)/12 = 3105.74 in.4
2/1/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [322.50 x (612.00 + 12)] x (12 in./ft.)3 = 116.46 ft3
Volumespan = N[A x L] = 1 x [322.50 x 612.00] x (12 in./ft.)3 = 114.22 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 116.46 = 3931.8 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 114.22 = 3856.2 lbs
Distributed Self Weight (ws) = = 75.61 plf
528 plf
120 plf
  ws = 75.61 plf
51.00 ft.
50.00 ft.
52.00 ft.
18813.89 lbs
18813.89 lbs
2/1/2023 3
CV = = 0.775
CV = 0.775 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.775) = 2140.0 psi
fb = = 1750.8 psi
 fb = 1750.8 psi < Fbx' = 2140.0 psi  (CSI = 0.82)   ➜  OK
2/1/2023 4
fv* = = 77.41 psi
 fv* = 77.41 psi < Fvx' = 304.75 psi  (CSI = 0.25)   ➜  OK
fv = = 85.82 psi
 fv = 85.82 psi < Fvx' = 304.75 psi  (CSI = 0.28)   ➜  OK
2/1/2023 5
ΔLL = = 1.85 in.
(L/d)LL = 612.00 / 1.85 = 332
 ΔLL = 1.85 in = L/332 > L/360   ➜  NG
ΔTL = = 2.53 in.
(L/d)TL = 612.00 / 2.53 = 242
 ΔTL = 2.53 in = L/242 < L/240   ➜  OK
Ab = b x lb = 10.75 x 12 = 129.00 in2
fc⊥ = = 145.8 psi
 fc⊥ = 145.8 psi < Fc⊥x' = 650.00 psi  (CSI = 0.22)   ➜  OK
2/1/2023 6
