Design Span (L): 4.75 ft.
Clear Span: 4.50 ft.
Total Span: 5.00 ft.
Live Load: 101 plf
Dead Load: 761 plf
Selfweight: 24.5 lbs
Dist. Selfweight: 5.17 plf
Total Weight: 25.8 lbs
Beam Design 2023A179
4/17/2023 1
4/17/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (57.00 + 3)] x (12 in./ft.)3 = 0.76 ft3
Volumespan = N[A x L] = 2 x [10.88 x 57.00] x (12 in./ft.)3 = 0.72 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.76 = 25.8 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.72 = 24.5 lbs
101 plf
761 plf
ws = 5.17 plf
4.75 ft.
4.50 ft.
5.00 ft.
2167.92 lbs
2167.92 lbs
4/17/2023 3
fb = = 1116.7 psi
 fb = 1116.7 psi < Fbx' = 1242.0 psi  (CSI = 0.90)   ➜  OK
4/17/2023 4
fv* = = 105.90 psi
 fv* = 105.90 psi < Fvx' = 207.00 psi  (CSI = 0.51)   ➜  OK
fv = = 142.04 psi
 fv = 142.04 psi < Fvx' = 207.00 psi  (CSI = 0.69)   ➜  OK
4/17/2023 5
ΔLL = = 0.01 in.
(L/d)LL = 57.00 / 0.01 = 7511
 ΔLL = 0.01 in = L/7511 < L/360   ➜  OK
ΔTL = = 0.07 in.
(L/d)TL = 57.00 / 0.07 = 875
 ΔTL = 0.07 in = L/875 < L/240   ➜  OK
fc⊥ = = 240.9 psi
 fc⊥ = 240.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.39)   ➜  OK
4/17/2023 6
