Size: 5.5 x 19.5
Design Span (L): 23.46 ft.
Clear Span: 23.00 ft.
Total Span: 23.92 ft.
Bearing (lb): 5.5 in.
Live Load: 713 plf
Dead Load: 241 plf
Selfweight: 589.9 lbs
Dist. Selfweight: 25.15 plf
Total Weight: 601.4 lbs
CV Volume Factor 0.935b - - - - -
Beam Design 2023A176
4/17/2023 1
d = 19.500 in.
A = 5.500 x 19.500 = 107.25 in.2
Sx = (5.500)(19.500)2/6 = 348.56 in.3
Sy = (5.500)2(19.500)/6 = 98.31 in.3
Ix = (5.500)(19.500)3/12 = 3398.48 in.4
Iy = (5.500)3(19.500)/12 = 270.36 in.4
4/17/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [107.25 x (281.50 + 5.5)] x (12 in./ft.)3 = 17.81 ft3
Volumespan = N[A x L] = 1 x [107.25 x 281.50] x (12 in./ft.)3 = 17.47 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 17.81 = 601.4 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 17.47 = 589.9 lbs
Distributed Self Weight (ws) = = 25.15 plf
713 plf
241 plf
  ws = 25.15 plf
23.46 ft.
23.00 ft.
23.92 ft.
11708.78 lbs
11708.78 lbs
4/17/2023 3
CV = = 0.935
CV = 0.935 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.935) = 2582.0 psi
fb = = 2318.7 psi
 fb = 2318.7 psi < Fbx' = 2582.0 psi  (CSI = 0.90)   ➜  OK
4/17/2023 4
fv* = = 138.37 psi
 fv* = 138.37 psi < Fvx' = 304.75 psi  (CSI = 0.45)   ➜  OK
fv = = 160.62 psi
 fv = 160.62 psi < Fvx' = 304.75 psi  (CSI = 0.53)   ➜  OK
4/17/2023 5
ΔLL = = 0.79 in.
(L/d)LL = 281.50 / 0.79 = 354
 ΔLL = 0.79 in = L/354 < L/180   ➜  OK
ΔTL = = 1.09 in.
(L/d)TL = 281.50 / 1.09 = 258
 ΔTL = 1.09 in = L/258 < L/120   ➜  OK
fc⊥ = = 387.1 psi
 fc⊥ = 387.1 psi < Fc⊥x' = 650.00 psi  (CSI = 0.60)   ➜  OK
4/17/2023 6
