Size: 3.5 x 18
Design Span (L): 11.46 ft.
Clear Span: 11.00 ft.
Total Span: 11.92 ft.
Bearing (lb): 5.5 in.
Live Load: 1236 plf
Dead Load: 401 plf
Selfweight: 169.2 lbs
Dist. Selfweight: 14.77 plf
Total Weight: 176.0 lbs
Beam Design 2023A175
4/17/2023 1
d = 18.000 in.
A = 3.500 x 18.000 = 63.00 in.2
Sx = (3.500)(18.000)2/6 = 189.00 in.3
Sy = (3.500)2(18.000)/6 = 36.75 in.3
Ix = (3.500)(18.000)3/12 = 1701.00 in.4
Iy = (3.500)3(18.000)/12 = 64.31 in.4
4/17/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [63.00 x (137.50 + 5.5)] x (12 in./ft.)3 = 5.21 ft3
Volumespan = N[A x L] = 1 x [63.00 x 137.50] x (12 in./ft.)3 = 5.01 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.21 = 176.0 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 5.01 = 169.2 lbs
Distributed Self Weight (ws) = = 14.77 plf
1236 plf
401 plf
  ws = 14.77 plf
11.46 ft.
11.00 ft.
11.92 ft.
9841.52 lbs
9841.52 lbs
4/17/2023 3
fb = = 1721.1 psi
 fb = 1721.1 psi < Fbx' = 2760.0 psi  (CSI = 0.62)   ➜  OK
4/17/2023 4
fv* = = 166.32 psi
 fv* = 166.32 psi < Fvx' = 304.75 psi  (CSI = 0.55)   ➜  OK
fv = = 225.31 psi
 fv = 225.31 psi < Fvx' = 304.75 psi  (CSI = 0.74)   ➜  OK
4/17/2023 5
ΔLL = = 0.16 in.
(L/d)LL = 137.50 / 0.16 = 878
 ΔLL = 0.16 in = L/878 < L/180   ➜  OK
ΔTL = = 0.21 in.
(L/d)TL = 137.50 / 0.21 = 657
 ΔTL = 0.21 in = L/657 < L/120   ➜  OK
Ab = b x lb = 3.5 x 5.5 = 19.25 in2
fc⊥ = = 511.2 psi
 fc⊥ = 511.2 psi < Fc⊥x' = 650.00 psi  (CSI = 0.79)   ➜  OK
4/17/2023 6
