Grade: SPF SS
Design Span (L): 8.25 ft.
Clear Span: 8.00 ft.
Total Span: 8.50 ft.
Live Load: 420 plf
Dead Load: 255 plf
Selfweight: 56.3 lbs
Dist. Selfweight: 6.82 plf
Total Weight: 58.0 lbs
Beam Design Billy 2023-1
4/16/2023 1
4/16/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (99.00 + 3)] x (12 in./ft.)3 = 1.99 ft3
Volumespan = N[A x L] = 2 x [16.88 x 99.00] x (12 in./ft.)3 = 1.93 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 1.99 = 58.0 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 1.93 = 56.3 lbs
420 plf
255 plf
ws = 6.82 plf
8.25 ft.
8.50 ft.
2897.73 lbs
2897.73 lbs
4/16/2023 3
fb = = 1100.0 psi
 fb = 1100.0 psi < Fbx' = 1437.5 psi  (CSI = 0.77)   ➜  OK
4/16/2023 4
fv* = = 96.59 psi
 fv* = 96.59 psi < Fvx' = 155.25 psi  (CSI = 0.62)   ➜  OK
fv = = 125.00 psi
 fv = 125.00 psi < Fvx' = 155.25 psi  (CSI = 0.81)   ➜  OK
4/16/2023 5
ΔLL = = 0.08 in.
(L/d)LL = 99.00 / 0.08 = 1207
 ΔLL = 0.08 in = L/1207 < L/180   ➜  OK
ΔTL = = 0.13 in.
(L/d)TL = 99.00 / 0.13 = 744
 ΔTL = 0.13 in = L/744 < L/120   ➜  OK
fc⊥ = = 322.0 psi
 fc⊥ = 322.0 psi < Fc⊥x' = 425.00 psi  (CSI = 0.76)   ➜  OK
4/16/2023 6
