Size: 5.5 x 24
Design Span (L): 22.75 ft.
Clear Span: 22.25 ft.
Total Span: 23.25 ft.
Live Load: 1034 plf
Dead Load: 180 plf
Selfweight: 704.1 lbs
Dist. Selfweight: 30.95 plf
Total Weight: 719.5 lbs
CV Volume Factor 0.919b - - - - -
Beam Design 2023A169
4/15/2023 1
d = 24.000 in.
A = 5.500 x 24.000 = 132.00 in.2
Sx = (5.500)(24.000)2/6 = 528.00 in.3
Sy = (5.500)2(24.000)/6 = 121.00 in.3
Ix = (5.500)(24.000)3/12 = 6336.00 in.4
Iy = (5.500)3(24.000)/12 = 332.75 in.4
4/15/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [132.00 x (273.00 + 6)] x (12 in./ft.)3 = 21.31 ft3
Volumespan = N[A x L] = 1 x [132.00 x 273.00] x (12 in./ft.)3 = 20.85 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 21.31 = 719.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 20.85 = 704.1 lbs
Distributed Self Weight (ws) = = 30.95 plf
1034 plf
180 plf
  ws = 30.95 plf
22.75 ft.
22.25 ft.
23.25 ft.
14472.52 lbs
14472.52 lbs
4/15/2023 3
CV = = 0.919
CV = 0.919 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.919) = 2536.7 psi
fb = = 1830.5 psi
 fb = 1830.5 psi < Fbx' = 2536.7 psi  (CSI = 0.72)   ➜  OK
4/15/2023 4
fv* = = 132.63 psi
 fv* = 132.63 psi < Fvx' = 304.75 psi  (CSI = 0.44)   ➜  OK
fv = = 160.92 psi
 fv = 160.92 psi < Fvx' = 304.75 psi  (CSI = 0.53)   ➜  OK
4/15/2023 5
ΔLL = = 0.55 in.
(L/d)LL = 273.00 / 0.55 = 500
 ΔLL = 0.55 in = L/500 < L/360   ➜  OK
ΔTL = = 0.66 in.
(L/d)TL = 273.00 / 0.66 = 415
 ΔTL = 0.66 in = L/415 < L/240   ➜  OK
fc⊥ = = 438.6 psi
 fc⊥ = 438.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.67)   ➜  OK
4/15/2023 6
