Size: 5.5 x 22.5
Design Span (L): 22.75 ft.
Clear Span: 22.25 ft.
Total Span: 23.25 ft.
Live Load: 1034 plf
Dead Load: 180 plf
Selfweight: 660.1 lbs
Dist. Selfweight: 29.01 plf
Total Weight: 674.6 lbs
CV Volume Factor 0.925b - - - - -
Beam Design 2023A167
4/15/2023 1
d = 22.500 in.
A = 5.500 x 22.500 = 123.75 in.2
Sx = (5.500)(22.500)2/6 = 464.06 in.3
Sy = (5.500)2(22.500)/6 = 113.44 in.3
Ix = (5.500)(22.500)3/12 = 5220.70 in.4
Iy = (5.500)3(22.500)/12 = 311.95 in.4
4/15/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [123.75 x (273.00 + 6)] x (12 in./ft.)3 = 19.98 ft3
Volumespan = N[A x L] = 1 x [123.75 x 273.00] x (12 in./ft.)3 = 19.55 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 19.98 = 674.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 19.55 = 660.1 lbs
Distributed Self Weight (ws) = = 29.01 plf
1034 plf
180 plf
  ws = 29.01 plf
22.75 ft.
22.25 ft.
23.25 ft.
14450.03 lbs
14450.03 lbs
4/15/2023 3
CV = = 0.925
CV = 0.925 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.925) = 2553.1 psi
fb = = 2079.5 psi
 fb = 2079.5 psi < Fbx' = 2553.1 psi  (CSI = 0.81)   ➜  OK
4/15/2023 4
fv* = = 143.13 psi
 fv* = 143.13 psi < Fvx' = 304.75 psi  (CSI = 0.47)   ➜  OK
fv = = 171.39 psi
 fv = 171.39 psi < Fvx' = 304.75 psi  (CSI = 0.56)   ➜  OK
4/15/2023 5
ΔLL = = 0.66 in.
(L/d)LL = 273.00 / 0.66 = 412
 ΔLL = 0.66 in = L/412 < L/360   ➜  OK
ΔTL = = 0.80 in.
(L/d)TL = 273.00 / 0.80 = 342
 ΔTL = 0.80 in = L/342 < L/240   ➜  OK
fc⊥ = = 437.9 psi
 fc⊥ = 437.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.67)   ➜  OK
4/15/2023 6
