Size: 5.5 x 24
Design Span (L): 23.21 ft.
Clear Span: 22.75 ft.
Total Span: 23.67 ft.
Bearing (lb): 5.5 in.
Live Load: 1335 plf
Dead Load: 250 plf
Selfweight: 718.2 lbs
Dist. Selfweight: 30.95 plf
Total Weight: 732.4 lbs
CV Volume Factor 0.917b - - - - -
Beam Design 2023A160
4/14/2023 1
d = 24.000 in.
A = 5.500 x 24.000 = 132.00 in.2
Sx = (5.500)(24.000)2/6 = 528.00 in.3
Sy = (5.500)2(24.000)/6 = 121.00 in.3
Ix = (5.500)(24.000)3/12 = 6336.00 in.4
Iy = (5.500)3(24.000)/12 = 332.75 in.4
4/14/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [132.00 x (278.50 + 5.5)] x (12 in./ft.)3 = 21.69 ft3
Volumespan = N[A x L] = 1 x [132.00 x 278.50] x (12 in./ft.)3 = 21.27 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 21.69 = 732.4 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 21.27 = 718.2 lbs
Distributed Self Weight (ws) = = 30.95 plf
1335 plf
250 plf
  ws = 30.95 plf
23.21 ft.
22.75 ft.
23.67 ft.
19121.78 lbs
19121.78 lbs
4/14/2023 3
CV = = 0.917
CV = 0.917 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.917) = 2531.6 psi
fb = = 2472.6 psi
 fb = 2472.6 psi < Fbx' = 2531.6 psi  (CSI = 0.98)   ➜  OK
4/14/2023 4
fv* = = 176.36 psi
 fv* = 176.36 psi < Fvx' = 304.75 psi  (CSI = 0.58)   ➜  OK
fv = = 213.08 psi
 fv = 213.08 psi < Fvx' = 304.75 psi  (CSI = 0.70)   ➜  OK
4/14/2023 5
ΔLL = = 0.76 in.
(L/d)LL = 278.50 / 0.76 = 364
 ΔLL = 0.76 in = L/364 < L/180   ➜  OK
ΔTL = = 0.92 in.
(L/d)TL = 278.50 / 0.92 = 301
 ΔTL = 0.92 in = L/301 < L/120   ➜  OK
fc⊥ = = 632.1 psi
 fc⊥ = 632.1 psi < Fc⊥x' = 650.00 psi  (CSI = 0.97)   ➜  OK
4/14/2023 6
