Grade: SP DSS
Design Span (L): 5.75 ft.
Clear Span: 5.50 ft.
Total Span: 6.00 ft.
Live Load: 610.3 plf
Dead Load: 122.4 plf
Selfweight: 41.4 lbs
Dist. Selfweight: 7.19 plf
Total Weight: 43.2 lbs
Beam Design 9811 Carter W 2023A14
1/31/2023 1
1/31/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (69.00 + 3)] x (12 in./ft.)3 = 1.16 ft3
Volumespan = N[A x L] = 2 x [13.88 x 69.00] x (12 in./ft.)3 = 1.11 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.16 = 43.2 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.11 = 41.4 lbs
610.3 plf
122.4 plf
ws = 7.19 plf
5.75 ft.
5.50 ft.
2219.68 lbs
2219.68 lbs
1/31/2023 3
Fbx' = (1950)(1.15)(1)(1)(1)(1)(1)(1) = 2242.5 psi
fb = = 857.7 psi
 fb = 857.7 psi < Fbx' = 2242.5 psi  (CSI = 0.38)   ➜  OK
1/31/2023 4
fv* = = 84.15 psi
 fv* = 84.15 psi < Fvx' = 201.25 psi  (CSI = 0.42)   ➜  OK
fv = = 114.98 psi
 fv = 114.98 psi < Fvx' = 201.25 psi  (CSI = 0.57)   ➜  OK
1/31/2023 5
ΔLL = = 0.04 in.
(L/d)LL = 69.00 / 0.04 = 1728
 ΔLL = 0.04 in = L/1728 < L/360   ➜  OK
ΔTL = = 0.05 in.
(L/d)TL = 69.00 / 0.05 = 1425
 ΔTL = 0.05 in = L/1425 < L/240   ➜  OK
fc⊥ = = 246.6 psi
 fc⊥ = 246.6 psi < Fc⊥x' = 660.00 psi  (CSI = 0.37)   ➜  OK
1/31/2023 6
