Live Load: 480 plf
Dead Load: 120 plf
Selfweight: 84.5 lbs
Dist. Selfweight: 7.19 plf
Total Weight: 86.3 lbs
Beam Design 2023A138
4/11/2023 1
4/11/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (141.00 + 3)] x (12 in./ft.)3 = 2.31 ft3
Volumespan = N[A x L] = 2 x [13.88 x 141.00] x (12 in./ft.)3 = 2.26 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 2.31 = 86.3 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 2.26 = 84.5 lbs
480 plf
120 plf
ws = 7.19 plf
3643.16 lbs
3643.16 lbs
4/11/2023 3
Fbx' = (800)(1.15)(1)(1)(1)(1)(1)(1.15) = 1058.0 psi
fb = = 2939.3 psi
 fb = 2939.3 psi > Fbx' = 1058.0 psi  (CSI = 2.78)   ➜  NG
4/11/2023 4
fv* = = 167.53 psi
 fv* = 167.53 psi < Fvx' = 201.25 psi  (CSI = 0.83)   ➜  OK
fv = = 192.83 psi
 fv = 192.83 psi < Fvx' = 201.25 psi  (CSI = 0.96)   ➜  OK
4/11/2023 5
ΔLL = = 0.74 in.
(L/d)LL = 141.00 / 0.74 = 190
 ΔLL = 0.74 in = L/190 < L/180   ➜  OK
ΔTL = = 0.94 in.
(L/d)TL = 141.00 / 0.94 = 150
 ΔTL = 0.94 in = L/150 < L/120   ➜  OK
fc⊥ = = 404.8 psi
 fc⊥ = 404.8 psi < Fc⊥x' = 565.00 psi  (CSI = 0.72)   ➜  OK
4/11/2023 6
