Grade: 24F-V3 1.8E SP/SP
Size: 3.5 x 15.125
Design Span (L): 22.25 ft.
Clear Span: 22.00 ft.
Total Span: 22.50 ft.
Live Load: 180 plf
Dead Load: 120 plf
Selfweight: 301.7 lbs
Dist. Selfweight: 13.56 plf
Total Weight: 305.1 lbs
Beam Design 2023A137
4/11/2023 1
d = 15.125 in.
A = 3.500 x 15.125 = 52.94 in.2
Sx = (3.500)(15.125)2/6 = 133.45 in.3
Sy = (3.500)2(15.125)/6 = 30.88 in.3
Ix = (3.500)(15.125)3/12 = 1009.19 in.4
Iy = (3.500)3(15.125)/12 = 54.04 in.4
4/11/2023 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [52.94 x (267.00 + 3)] x (12 in./ft.)3 = 8.27 ft3
Volumespan = N[A x L] = 1 x [52.94 x 267.00] x (12 in./ft.)3 = 8.18 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 8.27 = 305.1 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 8.18 = 301.7 lbs
Distributed Self Weight (ws) = = 13.56 plf
180 plf
120 plf
  ws = 13.56 plf
22.25 ft.
22.00 ft.
22.50 ft.
3527.57 lbs
3527.57 lbs
4/11/2023 3
lu/d = = 1.59
Rb = = 7.81
 Rb = 7.81 < 50   ➜  OK
4/11/2023 4
FbE = = 16709.46 psi
Fbx* = Fbx(CD)(CM)(Ct) = (2400)(1.00)(1)(1) = 2400.00 psi
CL =   = 0.992
CL = 0.992 < CV = 1.0
Fbx' = (2400)(1.00)(1)(1)(0.992) = 2380.2 psi
fb = = 1744.9 psi
 fb = 1744.9 psi < Fbx' = 2380.2 psi  (CSI = 0.73)   ➜  OK
fv* = = 87.65 psi
4/11/2023 5
 fv* = 87.65 psi < Fvx' = 300.00 psi  (CSI = 0.29)   ➜  OK
fv = = 98.84 psi
 fv = 98.84 psi < Fvx' = 300.00 psi  (CSI = 0.33)   ➜  OK
ΔLL = = 0.55 in.
(L/d)LL = 267.00 / 0.55 = 489
 ΔLL = 0.55 in = L/489 < L/360   ➜  OK
ΔTL = = 0.95 in.
(L/d)TL = 267.00 / 0.95 = 280
 ΔTL = 0.95 in = L/280 < L/240   ➜  OK
4/11/2023 6
fc⊥ = = 336.0 psi
 fc⊥ = 336.0 psi < Fc⊥x' = 740.00 psi  (CSI = 0.45)   ➜  OK
4/11/2023 7
