Grade: 24F-V3 1.8E SP/SP
Size: 3.125 x 15.125
Design Span (L): 22.25 ft.
Clear Span: 22.00 ft.
Total Span: 22.50 ft.
Live Load: 180 plf
Dead Load: 180 plf
Selfweight: 269.4 lbs
Dist. Selfweight: 12.11 plf
Total Weight: 272.4 lbs
Beam Design 2023A135
4/10/2023 1
b = 3.125 in.
d = 15.125 in.
A = 3.125 x 15.125 = 47.27 in.2
Sx = (3.125)(15.125)2/6 = 119.15 in.3
Sy = (3.125)2(15.125)/6 = 24.62 in.3
Ix = (3.125)(15.125)3/12 = 901.06 in.4
Iy = (3.125)3(15.125)/12 = 38.46 in.4
4/10/2023 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [47.27 x (267.00 + 3)] x (12 in./ft.)3 = 7.39 ft3
Volumespan = N[A x L] = 1 x [47.27 x 267.00] x (12 in./ft.)3 = 7.30 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 7.39 = 272.4 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 7.30 = 269.4 lbs
Distributed Self Weight (ws) = = 12.11 plf
180 plf
180 plf
  ws = 12.11 plf
22.25 ft.
22.00 ft.
22.50 ft.
4186.22 lbs
4186.22 lbs
4/10/2023 3
lu/d = = 1.59
Rb = = 8.75
 Rb = 8.75 < 50   ➜  OK
4/10/2023 4
Eminy' = Eminy(CM)(Ct) = 850000(1)(0.9) = 765000 psi
FbE = = 11988.61 psi
Fbx* = Fbx(CD)(CM)(Ct) = (2400)(1.00)(1)(0.8) = 1920.00 psi
CL =   = 0.991
CL = 0.991 < CV = 1.0
Fbx' = (2400)(1.00)(1)(0.8)(0.991) = 1902.1 psi
fb = = 2319.2 psi
 fb = 2319.2 psi > Fbx' = 1902.1 psi  (CSI = 1.22)   ➜  NG
Fvx' = (300)(1.00)(1)(0.8) = 240.00 psi
fv* = = 116.49 psi
4/10/2023 5
 fv* = 116.49 psi < Fvx' = 240.00 psi  (CSI = 0.49)   ➜  OK
fv = = 131.38 psi
 fv = 131.38 psi < Fvx' = 240.00 psi  (CSI = 0.55)   ➜  OK
ΔLL = = 0.68 in.
(L/d)LL = 267.00 / 0.68 = 393
 ΔLL = 0.68 in = L/393 < L/360   ➜  OK
ΔTL = = 1.41 in.
(L/d)TL = 267.00 / 1.41 = 190
 ΔTL = 1.41 in = L/190 > L/240   ➜  NG
Fc⊥x' = (740)(1)(0.8) = 592.00 psi
4/10/2023 6
fc⊥ = = 446.5 psi
 fc⊥ = 446.5 psi < Fc⊥x' = 592.00 psi  (CSI = 0.75)   ➜  OK
4/10/2023 7
