Grade: 24F-V3 1.8E SP/SP
Size: 3.5 x 16.5
Design Span (L): 22.25 ft.
Clear Span: 22.00 ft.
Total Span: 22.50 ft.
Live Load: 180 plf
Dead Load: 180 plf
Selfweight: 329.2 lbs
Dist. Selfweight: 14.79 plf
Total Weight: 332.9 lbs
Beam Design 2023A134
4/10/2023 1
d = 16.500 in.
A = 3.500 x 16.500 = 57.75 in.2
Sx = (3.500)(16.500)2/6 = 158.81 in.3
Sy = (3.500)2(16.500)/6 = 33.69 in.3
Ix = (3.500)(16.500)3/12 = 1310.20 in.4
Iy = (3.500)3(16.500)/12 = 58.95 in.4
4/10/2023 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [57.75 x (267.00 + 3)] x (12 in./ft.)3 = 9.02 ft3
Volumespan = N[A x L] = 1 x [57.75 x 267.00] x (12 in./ft.)3 = 8.92 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 9.02 = 332.9 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 8.92 = 329.2 lbs
Distributed Self Weight (ws) = = 14.79 plf
180 plf
180 plf
  ws = 14.79 plf
22.25 ft.
22.00 ft.
22.50 ft.
4216.44 lbs
4216.44 lbs
4/10/2023 3
lu/d = = 1.45
Rb = = 8.16
 Rb = 8.16 < 50   ➜  OK
4/10/2023 4
Eminy' = Eminy(CM)(Ct) = 850000(1)(0.9) = 765000 psi
FbE = = 13785.30 psi
Fbx* = Fbx(CD)(CM)(Ct) = (2400)(1.00)(1)(0.8) = 1920.00 psi
CL =   = 0.992
CL = 0.992 < CV = 1.0
Fbx' = (2400)(1.00)(1)(0.8)(0.992) = 1904.7 psi
fb = = 1752.5 psi
 fb = 1752.5 psi < Fbx' = 1904.7 psi  (CSI = 0.92)   ➜  OK
Fvx' = (300)(1.00)(1)(0.8) = 240.00 psi
fv* = = 94.92 psi
4/10/2023 5
 fv* = 94.92 psi < Fvx' = 240.00 psi  (CSI = 0.40)   ➜  OK
fv = = 108.30 psi
 fv = 108.30 psi < Fvx' = 240.00 psi  (CSI = 0.45)   ➜  OK
ΔLL = = 0.47 in.
(L/d)LL = 267.00 / 0.47 = 571
 ΔLL = 0.47 in = L/571 < L/360   ➜  OK
ΔTL = = 0.97 in.
(L/d)TL = 267.00 / 0.97 = 274
 ΔTL = 0.97 in = L/274 < L/240   ➜  OK
Fc⊥x' = (740)(1)(0.8) = 592.00 psi
4/10/2023 6
fc⊥ = = 401.6 psi
 fc⊥ = 401.6 psi < Fc⊥x' = 592.00 psi  (CSI = 0.68)   ➜  OK
4/10/2023 7
