Beam Design - Beam Load for 12.5 Span
Design Span (L): 12.25 ft.
Clear Span: 12.00 ft.
Total Span: 12.50 ft.
Live Load: 20 plf
Dead Load: 45 plf
Selfweight: 63.3 lbs
Dist. Selfweight: 5.17 plf
Total Weight: 64.6 lbs
Beam Design Jeff Chodrow Apex NC 20230401-35000008
4/10/2023 1
4/10/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (147.00 + 3)] x (12 in./ft.)3 = 1.89 ft3
Volumespan = N[A x L] = 2 x [10.88 x 147.00] x (12 in./ft.)3 = 1.85 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.89 = 64.6 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.85 = 63.3 lbs
20 plf
45 plf
ws = 5.17 plf
12.25 ft.
12.50 ft.
438.54 lbs
438.54 lbs
4/10/2023 3
fb = = 601.0 psi
 fb = 601.0 psi < Fbx' = 1242.0 psi  (CSI = 0.48)   ➜  OK
4/10/2023 4
fv* = = 26.72 psi
 fv* = 26.72 psi < Fvx' = 207.00 psi  (CSI = 0.13)   ➜  OK
fv = = 29.64 psi
 fv = 29.64 psi < Fvx' = 207.00 psi  (CSI = 0.14)   ➜  OK
4/10/2023 5
ΔLL = = 0.07 in.
(L/d)LL = 147.00 / 0.07 = 2211
 ΔLL = 0.07 in = L/2211 < L/360   ➜  OK
ΔTL = = 0.23 in.
(L/d)TL = 147.00 / 0.23 = 630
 ΔTL = 0.23 in = L/630 < L/240   ➜  OK
fc⊥ = = 48.7 psi
 fc⊥ = 48.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.08)   ➜  OK
4/10/2023 6
