Species: Hem-Fir
Grade: HF No.2
Design Span (L): 7.25 ft.
Clear Span: 7.00 ft.
Total Span: 7.50 ft.
Live Load: 230 plf
Dead Load: 70 plf
Selfweight: 32.6 lbs
Dist. Selfweight: 4.49 plf
Total Weight: 33.7 lbs
Beam Design 2023A131
4/1/2023 1
G = 0.43
4/1/2023 2
= 29.74 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (87.00 + 3)] x (12 in./ft.)3 = 1.13 ft3
Volumespan = N[A x L] = 2 x [10.88 x 87.00] x (12 in./ft.)3 = 1.10 ft3
Total Weight (WT) = ρw x Volumetotal = 29.74 x 1.13 = 33.7 lbs
Self Weight (WS) = ρw x Volumespan = 29.74 x 1.10 = 32.6 lbs
Distributed Self Weight (ws) = = 4.49 plf
230 plf
70 plf
ws = 4.49 plf
7.25 ft.
7.00 ft.
7.50 ft.
1141.85 lbs
1141.85 lbs
4/1/2023 3
Fbx' = (850)(1.15)(1)(1)(1)(1.2)(1)(1) = 1173.0 psi
fb = = 913.5 psi
 fb = 913.5 psi < Fbx' = 1173.0 psi  (CSI = 0.78)   ➜  OK
4/1/2023 4
Fvx' = (150)(1.15)(1)(1)(1) = 172.50 psi
fv* = = 63.44 psi
 fv* = 63.44 psi < Fvx' = 172.50 psi  (CSI = 0.37)   ➜  OK
fv = = 76.12 psi
 fv = 76.12 psi < Fvx' = 172.50 psi  (CSI = 0.44)   ➜  OK
4/1/2023 5
ΔLL = = 0.12 in.
(L/d)LL = 87.00 / 0.12 = 754
 ΔLL = 0.12 in = L/754 < L/360   ➜  OK
ΔTL = = 0.15 in.
(L/d)TL = 87.00 / 0.15 = 569
 ΔTL = 0.15 in = L/569 < L/240   ➜  OK
fc⊥ = = 126.9 psi
 fc⊥ = 126.9 psi < Fc⊥x' = 405.00 psi  (CSI = 0.31)   ➜  OK
4/1/2023 6
