Beam Design - Vetter Villa 01
Design Span (L): 18.38 ft.
Clear Span: 18.25 ft.
Total Span: 18.50 ft.
Bearing (lb): 1.5 in.
Live Load: 50 plf
Dead Load: 50 plf
Selfweight: 241.1 lbs
Dist. Selfweight: 13.12 plf
Total Weight: 242.8 lbs
Notes: Garage Door Header
CL Beam Stability Factor 0.979 - - - - -
Beam Design 2023A126
3/29/2023 1
3/29/2023 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (220.50 + 1.5)] x (12 in./ft.)3 = 6.50 ft3
Volumespan = N[A x L] = 3 x [16.88 x 220.50] x (12 in./ft.)3 = 6.46 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 6.50 = 242.8 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 6.46 = 241.1 lbs
50 plf
50 plf
ws = 13.12 plf
18.38 ft.
18.25 ft.
18.50 ft.
1046.40 lbs
1046.40 lbs
3/29/2023 3
lu = Unbraced Length = 18.375 ft.
lu/d = = 19.60
le = 1.63lu + 3d = 1.63(220.5) + 3(11.25) = 393.17 in. = 32.76 ft.  (NDS Table 3.3.3)
Rb = = 14.78
 Rb = 14.78 < 50   ➜  OK
3/29/2023 4
FbE = = 2801.88 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (750)(1.15)(1)(1)(1)(1)(1) = 862.50 psi
CL =   = 0.979
Fbx' = (750)(1.15)(1)(1)(0.979)(1)(1)(1) = 844.3 psi
fb = = 603.6 psi
 fb = 603.6 psi < Fbx' = 844.3 psi  (CSI = 0.71)   ➜  OK
fv* = = 27.65 psi
 fv* = 27.65 psi < Fvx' = 201.25 psi  (CSI = 0.14)   ➜  OK
fv = = 30.79 psi
 fv = 30.79 psi < Fvx' = 201.25 psi  (CSI = 0.15)   ➜  OK
3/29/2023 5
ΔLL = = 0.17 in.
(L/d)LL = 220.50 / 0.17 = 1285
 ΔLL = 0.17 in = L/1285 < L/360   ➜  OK
ΔTL = = 0.39 in.
(L/d)TL = 220.50 / 0.39 = 568
 ΔTL = 0.39 in = L/568 < L/240   ➜  OK
fc⊥ = = 155.0 psi
 fc⊥ = 155.0 psi < Fc⊥x' = 565.00 psi  (CSI = 0.27)   ➜  OK
3/29/2023 6
