Design Span (L): 4.75 ft.
Clear Span: 4.50 ft.
Total Span: 5.00 ft.
Live Load: 600 plf
Dead Load: 360 plf
Selfweight: 41.6 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 43.7 lbs
Beam Design 2023A122
3/29/2023 1
3/29/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (57.00 + 3)] x (12 in./ft.)3 = 1.17 ft3
Volumespan = N[A x L] = 2 x [16.88 x 57.00] x (12 in./ft.)3 = 1.11 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.17 = 43.7 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.11 = 41.6 lbs
600 plf
360 plf
ws = 8.75 plf
4.75 ft.
4.50 ft.
5.00 ft.
2421.87 lbs
2421.87 lbs
3/29/2023 3
lu/d = = 2.13
Rb = = 7.86
 Rb = 7.86 < 50   ➜  OK
3/29/2023 4
FbE = = 9902.91 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (750)(1.15)(1)(1)(1)(1)(1) = 862.50 psi
CL =   = 0.995
Fbx' = (750)(1.15)(1)(1)(0.995)(1)(1)(1) = 858.4 psi
fb = = 518.1 psi
 fb = 518.1 psi < Fbx' = 858.4 psi  (CSI = 0.60)   ➜  OK
fv* = = 61.89 psi
 fv* = 61.89 psi < Fvx' = 201.25 psi  (CSI = 0.31)   ➜  OK
fv = = 102.26 psi
 fv = 102.26 psi < Fvx' = 201.25 psi  (CSI = 0.51)   ➜  OK
3/29/2023 5
ΔLL = = 0.01 in.
(L/d)LL = 57.00 / 0.01 = 4133
 ΔLL = 0.01 in = L/4133 < L/360   ➜  OK
ΔTL = = 0.02 in.
(L/d)TL = 57.00 / 0.02 = 2560
 ΔTL = 0.02 in = L/2560 < L/240   ➜  OK
fc⊥ = = 269.1 psi
 fc⊥ = 269.1 psi < Fc⊥x' = 565.00 psi  (CSI = 0.48)   ➜  OK
3/29/2023 6
