Beam Design - Header above Garage Door Check
Grade: SPF No.2
Design Span (L): 12.38 ft.
Clear Span: 12.00 ft.
Total Span: 12.75 ft.
Bearing (lb): 4.5 in.
Live Load: 227 plf
Dead Load: 156 plf
Selfweight: 126.6 lbs
Dist. Selfweight: 10.23 plf
Total Weight: 130.4 lbs
Notes: Check on as Modified Header.
Beam Design Bouma Design 1166 Vidal Street, Sarnia 230129
1/25/2023 1
1/25/2023 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (148.50 + 4.5)] x (12 in./ft.)3 = 4.48 ft3
Volumespan = N[A x L] = 3 x [16.88 x 148.50] x (12 in./ft.)3 = 4.35 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 4.48 = 130.4 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 4.35 = 126.6 lbs
Distributed Self Weight (ws) = = 10.23 plf
227 plf
156 plf
ws = 10.23 plf
12.38 ft.
12.75 ft.
2506.84 lbs
2506.84 lbs
1/25/2023 3
fb = = 951.6 psi
 fb = 951.6 psi < Fbx' = 1006.2 psi  (CSI = 0.95)   ➜  OK
1/25/2023 4
fv* = = 61.17 psi
 fv* = 61.17 psi < Fvx' = 155.25 psi  (CSI = 0.39)   ➜  OK
fv = = 72.09 psi
 fv = 72.09 psi < Fvx' = 155.25 psi  (CSI = 0.46)   ➜  OK
1/25/2023 5
ΔLL = = 0.16 in.
(L/d)LL = 148.50 / 0.16 = 927
 ΔLL = 0.16 in = L/927 < L/360   ➜  OK
ΔTL = = 0.28 in.
(L/d)TL = 148.50 / 0.28 = 535
 ΔTL = 0.28 in = L/535 < L/240   ➜  OK
Ab = b x lb = 1.5 x 4.5 = 6.75 in2
fc⊥ = = 123.8 psi
 fc⊥ = 123.8 psi < Fc⊥x' = 425.00 psi  (CSI = 0.29)   ➜  OK
1/25/2023 6
