Grade: DF SS
Design Span (L): 25.75 ft.
Clear Span: 25.50 ft.
Total Span: 26.00 ft.
Selfweight: 103.2 lbs
Dist. Selfweight: 4.01 plf
Total Weight: 104.2 lbs
Load Duration: 1.60
Beam Design Santiago
3/28/2023 1
3/28/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (309.00 + 3)] x (12 in./ft.)3 = 3.05 ft3
Volumespan = N[A x L] = 1 x [16.88 x 309.00] x (12 in./ft.)3 = 3.02 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.05 = 104.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.02 = 103.2 lbs
ws = 4.01 plf
25.75 ft.
25.50 ft.
26.00 ft.
2327.11 lbs
2327.11 lbs
3/28/2023 3
Fbx' = (1500)(1.60)(1)(1)(1)(1)(1)(1) = 2400.0 psi
fb = = 5627.0 psi
 fb = 5627.0 psi > Fbx' = 2400.0 psi  (CSI = 2.34)   ➜  NG
3/28/2023 4
Fvx' = (180)(1.60)(1)(1)(1) = 288.00 psi
fv* = = 189.95 psi
 fv* = 189.95 psi < Fvx' = 288.00 psi  (CSI = 0.66)   ➜  OK
fv = = 204.86 psi
 fv = 204.86 psi < Fvx' = 288.00 psi  (CSI = 0.71)   ➜  OK
3/28/2023 5
ΔLL = = 2.93 in.
(L/d)LL = 309.00 / 2.93 = 106
 ΔLL = 2.93 in = L/106 > L/360   ➜  NG
ΔTL = = 5.24 in.
(L/d)TL = 309.00 / 5.24 = 59
 ΔTL = 5.24 in = L/59 > L/240   ➜  NG
fc⊥ = = 517.1 psi
 fc⊥ = 517.1 psi < Fc⊥x' = 625.00 psi  (CSI = 0.83)   ➜  OK
3/28/2023 6
