Grade: SPF SS
Design Span (L): 10.08 ft.
Clear Span: 9.83 ft.
Total Span: 10.33 ft.
Dead Load: 200 plf
Selfweight: 56.5 lbs
Dist. Selfweight: 5.61 plf
Total Weight: 57.9 lbs
Defl. Limits: 480|360
Beam Design 2023A116
3/27/2023 1
3/27/2023 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (120.96 + 3)] x (12 in./ft.)3 = 1.99 ft3
Volumespan = N[A x L] = 2 x [13.88 x 120.96] x (12 in./ft.)3 = 1.94 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 1.99 = 57.9 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 1.94 = 56.5 lbs
200 plf
ws = 5.61 plf
10.08 ft.
9.83 ft.
10.33 ft.
1578.46 lbs
1578.46 lbs
3/27/2023 3
Fbx' = (1250)(1.15)(1)(1)(1)(1.1)(1)(1) = 1581.3 psi
fb = = 1088.7 psi
 fb = 1088.7 psi < Fbx' = 1581.3 psi  (CSI = 0.69)   ➜  OK
3/27/2023 4
fv* = = 70.52 psi
 fv* = 70.52 psi < Fvx' = 155.25 psi  (CSI = 0.45)   ➜  OK
fv = = 83.26 psi
 fv = 83.26 psi < Fvx' = 155.25 psi  (CSI = 0.54)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
3/27/2023 5
ΔLL = = 0.08 in.
(L/d)LL = 120.96 / 0.08 = 1546
 ΔLL = 0.08 in = L/1546 < L/480   ➜  OK
ΔTL = = 0.24 in.
(L/d)TL = 120.96 / 0.24 = 506
 ΔTL = 0.24 in = L/506 < L/360   ➜  OK
fc⊥ = = 175.4 psi
 fc⊥ = 175.4 psi < Fc⊥x' = 425.00 psi  (CSI = 0.41)   ➜  OK
3/27/2023 6
