Grade: SPF SS
Size: 4 x 4
Design Span (L): 3.75 ft.
Clear Span: 3.50 ft.
Total Span: 4.00 ft.
Live Load: 0 lbs
Dead Load: 100 lbs
Selfweight: 9.3 lbs
Dist. Selfweight: 2.48 plf
Total Weight: 9.9 lbs
Beam Design 2023A114
3/26/2023 1
d = 3.500 in.
3/26/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [12.25 x (45.00 + 3)] x (12 in./ft.)3 = 0.34 ft3
Volumespan = N[A x L] = 1 x [12.25 x 45.00] x (12 in./ft.)3 = 0.32 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 0.34 = 9.9 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 0.32 = 9.3 lbs
Distributed Self Weight (ws) = = 2.48 plf
0 lbs
100 lbs
ws = 2.48 plf
3.75 ft.
3.50 ft.
4.00 ft.
54.95 lbs
54.95 lbs
3/26/2023 3
Fbx' = (1250)(0.9)(1)(1)(1)(1.5)(1)(1) = 1687.5 psi
fb = = 164.7 psi
 fb = 164.7 psi < Fbx' = 1687.5 psi  (CSI = 0.10)   ➜  OK
3/26/2023 4
Fvx' = (135)(0.9)(1)(1)(1) = 121.50 psi
fv* = = 6.60 psi
 fv* = 6.60 psi < Fvx' = 121.50 psi  (CSI = 0.05)   ➜  OK
fv = = 6.69 psi
 fv = 6.69 psi < Fvx' = 121.50 psi  (CSI = 0.06)   ➜  OK
3/26/2023 5
ΔLL =   =   = 0.00 in.
(L/d)LL = 45.00 / 0.00 = ∞
ΔTL =   =   = 0.01 in.
(L/d)TL = 45.00 / 0.01 = 4202
 ΔTL = 0.01 in = L/4202 < L/240   ➜  OK
fc⊥ = = 5.2 psi
 fc⊥ = 5.2 psi < Fc⊥x' = 425.00 psi  (CSI = 0.01)   ➜  OK
3/26/2023 6
