Size: 5.5 x 24
Design Span (L): 39.75 ft.
Clear Span: 39.50 ft.
Total Span: 40.00 ft.
Live Load: 750 plf
Dead Load: 375 plf
Selfweight: 1230.2 lbs
Dist. Selfweight: 30.95 plf
Total Weight: 1237.9 lbs
Load Duration: 1.60
CV Volume Factor 0.869b - - - - -
Beam Design 2023A112
3/25/2023 1
d = 24.000 in.
A = 5.500 x 24.000 = 132.00 in.2
Sx = (5.500)(24.000)2/6 = 528.00 in.3
Sy = (5.500)2(24.000)/6 = 121.00 in.3
Ix = (5.500)(24.000)3/12 = 6336.00 in.4
Iy = (5.500)3(24.000)/12 = 332.75 in.4
3/25/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [132.00 x (477.00 + 3)] x (12 in./ft.)3 = 36.67 ft3
Volumespan = N[A x L] = 1 x [132.00 x 477.00] x (12 in./ft.)3 = 36.44 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 36.67 = 1237.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 36.44 = 1230.2 lbs
Distributed Self Weight (ws) = = 30.95 plf
750 plf
375 plf
  ws = 30.95 plf
39.75 ft.
39.50 ft.
40.00 ft.
23118.96 lbs
23118.96 lbs
3/25/2023 3
CV = = 0.869
CV = 0.869 < CL = 1
Fbx' = (2400)(1.60)(1)(1)(0.869) = 3337.7 psi
fb = = 5188.8 psi
 fb = 5188.8 psi > Fbx' = 3337.7 psi  (CSI = 1.55)   ➜  NG
3/25/2023 4
Fvx' = (265)(1.60)(1)(1) = 424.00 psi
fv* = = 234.80 psi
 fv* = 234.80 psi < Fvx' = 424.00 psi  (CSI = 0.55)   ➜  OK
fv = = 261.07 psi
 fv = 261.07 psi < Fvx' = 424.00 psi  (CSI = 0.62)   ➜  OK
3/25/2023 5
ΔLL = = 3.69 in.
(L/d)LL = 477.00 / 3.69 = 129
 ΔLL = 3.69 in = L/129 > L/240   ➜  NG
ΔTL = = 5.69 in.
(L/d)TL = 477.00 / 5.69 = 84
 ΔTL = 5.69 in = L/84 > L/180   ➜  NG
fc⊥ = = 1401.1 psi
 fc⊥ = 1401.1 psi > Fc⊥x' = 650.00 psi  (CSI = 2.16)   ➜  NG
3/25/2023 6
