Size: 5.5 x 36
Design Span (L): 44.54 ft.
Clear Span: 44.08 ft.
Total Span: 45.00 ft.
Bearing (lb): 5.5 in.
Live Load: 450 plf
Dead Load: 225 plf
Selfweight: 2067.7 lbs
Dist. Selfweight: 46.42 plf
Total Weight: 2089.0 lbs
CV Volume Factor 0.825b - - - - -
Beam Design 2023A110
3/24/2023 1
d = 36.000 in.
A = 5.500 x 36.000 = 198.00 in.2
Sx = (5.500)(36.000)2/6 = 1188.00 in.3
Sy = (5.500)2(36.000)/6 = 181.50 in.3
Ix = (5.500)(36.000)3/12 = 21384.00 in.4
Iy = (5.500)3(36.000)/12 = 499.13 in.4
3/24/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [198.00 x (534.50 + 5.5)] x (12 in./ft.)3 = 61.88 ft3
Volumespan = N[A x L] = 1 x [198.00 x 534.50] x (12 in./ft.)3 = 61.25 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 61.88 = 2089.0 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 61.25 = 2067.7 lbs
Distributed Self Weight (ws) = = 46.42 plf
450 plf
225 plf
  ws = 46.42 plf
44.54 ft.
44.08 ft.
45.00 ft.
16232.11 lbs
16232.11 lbs
3/24/2023 3
CV = = 0.825
CV = 0.825 < CL = 1
Fbx' = (2400)(1.00)(1)(1)(0.825) = 1980.5 psi
fb = = 1807.2 psi
 fb = 1807.2 psi < Fbx' = 1980.5 psi  (CSI = 0.91)   ➜  OK
3/24/2023 4
fv* = = 105.32 psi
 fv* = 105.32 psi < Fvx' = 265.00 psi  (CSI = 0.40)   ➜  OK
fv = = 121.72 psi
 fv = 121.72 psi < Fvx' = 265.00 psi  (CSI = 0.46)   ➜  OK
3/24/2023 5
ΔLL = = 1.04 in.
(L/d)LL = 534.50 / 1.04 = 516
 ΔLL = 1.04 in = L/516 < L/360   ➜  OK
ΔTL = = 1.66 in.
(L/d)TL = 534.50 / 1.66 = 322
 ΔTL = 1.66 in = L/322 < L/240   ➜  OK
fc⊥ = = 536.6 psi
 fc⊥ = 536.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.83)   ➜  OK
3/24/2023 6
