Size: 6.75 x 24
Design Span (L): 29.50 ft.
Clear Span: 29.00 ft.
Total Span: 30.00 ft.
Live Load: 910 plf
Selfweight: 1120.4 lbs
Dist. Selfweight: 37.98 plf
Total Weight: 1139.4 lbs
Lateral Support: 16' o/c
CL Beam Stability Factor 0.949 - - - - -
CV Volume Factor 0.877b - - - - -
Beam Design 2023A107
3/24/2023 1
b = 6.750 in.
d = 24.000 in.
A = 6.750 x 24.000 = 162.00 in.2
Sx = (6.750)(24.000)2/6 = 648.00 in.3
Sy = (6.750)2(24.000)/6 = 182.25 in.3
Ix = (6.750)(24.000)3/12 = 7776.00 in.4
Iy = (6.750)3(24.000)/12 = 615.09 in.4
3/24/2023 2
Volumetotal = N[A x (L + lb)] = 1 x [162.00 x (354.00 + 6)] x (12 in./ft.)3 = 33.75 ft3
Volumespan = N[A x L] = 1 x [162.00 x 354.00] x (12 in./ft.)3 = 33.19 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 33.75 = 1139.4 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 33.19 = 1120.4 lbs
Distributed Self Weight (ws) = = 37.98 plf
910 plf
  ws = 37.98 plf
29.50 ft.
29.00 ft.
30.00 ft.
15344.72 lbs
15344.72 lbs
3/24/2023 3
lu = Unbraced Length = 16 ft.
lu/d = = 8.00
le = 1.63lu + 3d = 1.63(192.0) + 3(24) = 384.96 in. = 32.08 ft.  (NDS Table 3.3.3)
Rb = = 14.24
 Rb = 14.24 < 50   ➜  OK
3/24/2023 4
FbE = = 5030.15 psi
CL =   = 0.949
CV = = 0.877
CV = 0.877 < CL = 0.949
Fbx' = (2400)(1.15)(1)(1)(0.877) = 2421.5 psi
fb = = 2060.8 psi
 fb = 2060.8 psi < Fbx' = 2421.5 psi  (CSI = 0.85)   ➜  OK
fv* = = 120.77 psi
3/24/2023 5
 fv* = 120.77 psi < Fvx' = 304.75 psi  (CSI = 0.40)   ➜  OK
fv = = 139.71 psi
 fv = 139.71 psi < Fvx' = 304.75 psi  (CSI = 0.46)   ➜  OK
ΔLL = = 1.11 in.
(L/d)LL = 354.00 / 1.11 = 320
 ΔLL = 1.11 in = L/320 < L/180   ➜  OK
ΔTL = = 1.25 in.
(L/d)TL = 354.00 / 1.25 = 284
 ΔTL = 1.25 in = L/284 < L/120   ➜  OK
3/24/2023 6
fc⊥ = = 378.9 psi
 fc⊥ = 378.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.58)   ➜  OK
3/24/2023 7
