Grade: SPF No.2
Design Span (L): 6.25 ft.
Clear Span: 6.00 ft.
Total Span: 6.50 ft.
Live Load: 770 plf
Dead Load: 426.5 plf
Selfweight: 63.9 lbs
Dist. Selfweight: 10.23 plf
Total Weight: 66.5 lbs
Beam Design KAZ Architecture 2023A102
3/23/2023 1
3/23/2023 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (75.00 + 3)] x (12 in./ft.)3 = 2.29 ft3
Volumespan = N[A x L] = 3 x [16.88 x 75.00] x (12 in./ft.)3 = 2.20 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 2.29 = 66.5 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 2.20 = 63.9 lbs
Distributed Self Weight (ws) = = 10.23 plf
770 plf
426.5 plf
ws = 10.23 plf
6.25 ft.
6.50 ft.
3921.87 lbs
3921.87 lbs
3/23/2023 3
fb = = 744.9 psi
 fb = 744.9 psi < Fbx' = 1006.2 psi  (CSI = 0.74)   ➜  OK
3/23/2023 4
fv* = = 78.21 psi
 fv* = 78.21 psi < Fvx' = 155.25 psi  (CSI = 0.50)   ➜  OK
fv = = 111.73 psi
 fv = 111.73 psi < Fvx' = 155.25 psi  (CSI = 0.72)   ➜  OK
3/23/2023 5
ΔLL = = 0.04 in.
(L/d)LL = 75.00 / 0.04 = 2121
 ΔLL = 0.04 in = L/2121 < L/360   ➜  OK
ΔTL = = 0.06 in.
(L/d)TL = 75.00 / 0.06 = 1353
 ΔTL = 0.06 in = L/1353 < L/240   ➜  OK
fc⊥ = = 290.5 psi
 fc⊥ = 290.5 psi < Fc⊥x' = 425.00 psi  (CSI = 0.68)   ➜  OK
3/23/2023 6
