Grade: DF No.3
Design Span (L): 7.88 ft.
Clear Span: 7.75 ft.
Total Span: 8.00 ft.
Bearing (lb): 1.5 in.
Live Load: 130 plf
Dead Load: 26 plf
Selfweight: 21.1 lbs
Dist. Selfweight: 2.68 plf
Total Weight: 21.4 lbs
Beam Design 2022A98
2/24/2022 1
DF No.3 900 575 180 625 1350 1600000 580000 0.5
Beam Design 2022A98
2/24/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (94.50 + 1.5)] x (12 in./ft.)3 = 0.60 ft3
Volumespan = N[A x L] = 1 x [10.88 x 94.50] x (12 in./ft.)3 = 0.59 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 0.60 = 21.4 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 0.59 = 21.1 lbs
Distributed Self Weight (ws) = = 2.68 plf
130 plf
26 plf
ws = 2.68 plf
7.88 ft.
7.75 ft.
634.71 lbs
634.71 lbs
Beam Design 2022A98
2/24/2022 3
fb = = 1123.3 psi
 fb = 1123.3 psi < Fbx' = 1242.0 psi  (CSI = 0.90)   ➜  OK
Beam Design 2022A98
2/24/2022 4
fv* = = 72.96 psi
 fv* = 72.96 psi < Fvx' = 200.79 psi  (CSI = 0.36)   ➜  OK
fv = = 86.18 psi
 fv = 86.18 psi < Fvx' = 200.79 psi  (CSI = 0.43)   ➜  OK
Beam Design 2022A98
2/24/2022 5
ΔLL = = 0.16 in.
(L/d)LL = 94.50 / 0.16 = 576
 ΔLL = 0.16 in = L/576 < L/360   ➜  OK
ΔTL = = 0.20 in.
(L/d)TL = 94.50 / 0.20 = 472
 ΔTL = 0.20 in = L/472 < L/240   ➜  OK
fc⊥ = = 282.1 psi
 fc⊥ = 282.1 psi < Fc⊥x' = 418.75 psi  (CSI = 0.67)   ➜  OK
Beam Design 2022A98
2/24/2022 6
