Grade: DF No.1
Design Span (L): 3.88 ft.
Clear Span: 3.75 ft.
Total Span: 4.00 ft.
Bearing (lb): 1.5 in.
Live Load: 1600 lbs
Dead Load: 160 lbs
Selfweight: 12.8 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 13.2 lbs
CL Beam Stability Factor 0.942 - - - - -
Beam Design 2022A94
2/24/2022 1
Beam Design 2022A94
2/24/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (46.50 + 1.5)] x (12 in./ft.)3 = 0.39 ft3
Volumespan = N[A x L] = 1 x [13.88 x 46.50] x (12 in./ft.)3 = 0.37 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.39 = 13.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.37 = 12.8 lbs
1600 lbs
160 lbs
ws = 3.30 plf
3.88 ft.
3.75 ft.
4.00 ft.
886.59 lbs
886.59 lbs
Beam Design 2022A94
2/24/2022 3
lu = Unbraced Length = 3.875 ft.
lu/d = = 5.03
le = 1.8lu = 1.8(46.5) = 83.70 in. = 6.98 ft.  (NDS Table 3.3.3)
Rb = = 18.55
 Rb = 18.55 < 50   ➜  OK
Beam Design 2022A94
2/24/2022 4
Eminy' = Eminy(CM)(Ct)(Ci) = 620000(1)(1)(1) = 620000 psi
FbE = = 2162.16 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1000)(1.15)(1)(1)(1.1)(1)(1) = 1265.00 psi
CL =   = 0.942
Fbx' = (1000)(1.15)(1)(1)(0.942)(1.1)(1)(1) = 1191.8 psi
fb = = 960.0 psi
 fb = 960.0 psi < Fbx' = 1191.8 psi  (CSI = 0.81)   ➜  OK
fv* = = 95.55 psi
 fv* = 95.55 psi < Fvx' = 207.00 psi  (CSI = 0.46)   ➜  OK
fv = = 95.83 psi
 fv = 95.83 psi < Fvx' = 207.00 psi  (CSI = 0.46)   ➜  OK
Beam Design 2022A94
2/24/2022 5
ΔLL =   =   = 0.02 in.
(L/d)LL = 46.50 / 0.02 = 2333
 ΔLL = 0.02 in = L/2333 < L/180   ➜  OK
ΔTL =   =   = 0.02 in.
(L/d)TL = 46.50 / 0.02 = 2112
 ΔTL = 0.02 in = L/2112 < L/120   ➜  OK
fc⊥ = = 394.0 psi
 fc⊥ = 394.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.63)   ➜  OK
Beam Design 2022A94
2/24/2022 6
