Grade: DF No.1
Design Span (L): 3.88 ft.
Clear Span: 3.75 ft.
Total Span: 4.00 ft.
Bearing (lb): 1.5 in.
Live Load: 800 lbs
Dead Load: 80 lbs
Selfweight: 13.2 lbs
Dist. Selfweight: 3.42 plf
Total Weight: 13.7 lbs
CL Beam Stability Factor 0.929 - - - - -
Beam Design 2022A91
2/24/2022 1
Beam Design 2022A91
2/24/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (46.50 + 1.5)] x (12 in./ft.)3 = 0.39 ft3
Volumespan = N[A x L] = 1 x [13.88 x 46.50] x (12 in./ft.)3 = 0.37 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 0.39 = 13.7 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 0.37 = 13.2 lbs
Distributed Self Weight (ws) = = 3.42 plf
800 lbs
80 lbs
ws = 3.42 plf
3.88 ft.
3.75 ft.
4.00 ft.
446.83 lbs
446.83 lbs
Beam Design 2022A91
2/24/2022 3
lu = Unbraced Length = 3.875 ft.
lu/d = = 5.03
le = 1.8lu = 1.8(46.5) = 83.70 in. = 6.98 ft.  (NDS Table 3.3.3)
Rb = = 18.55
 Rb = 18.55 < 50   ➜  OK
Beam Design 2022A91
2/24/2022 4
Eminy' = Eminy(CM)(Ct)(Ci) = 620000(0.9)(1)(1) = 558000 psi
FbE = = 1945.95 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (1000)(1.15)(1)(1)(1.1)(1)(1) = 1265.00 psi
CL =   = 0.929
Fbx' = (1000)(1.15)(1)(1)(0.929)(1.1)(1)(1) = 1175.4 psi
fb = = 481.8 psi
 fb = 481.8 psi < Fbx' = 1175.4 psi  (CSI = 0.41)   ➜  OK
fv* = = 48.00 psi
 fv* = 48.00 psi < Fvx' = 200.79 psi  (CSI = 0.24)   ➜  OK
fv = = 48.28 psi
 fv = 48.28 psi < Fvx' = 200.79 psi  (CSI = 0.24)   ➜  OK
Beam Design 2022A91
2/24/2022 5
Ex' = Ex(CM)(Ct)(Ci) = 1700000(0.9)(1)(1) = 1530000 psi
ΔLL =   =   = 0.01 in.
(L/d)LL = 46.50 / 0.01 = 4200
 ΔLL = 0.01 in = L/4200 < L/360   ➜  OK
ΔTL =   =   = 0.01 in.
(L/d)TL = 46.50 / 0.01 = 3783
 ΔTL = 0.01 in = L/3783 < L/240   ➜  OK
fc⊥ = = 198.6 psi
 fc⊥ = 198.6 psi < Fc⊥x' = 418.75 psi  (CSI = 0.47)   ➜  OK
Beam Design 2022A91
2/24/2022 6
