Size: 2 x 4
Design Span (L): 5.75 ft.
Clear Span: 5.50 ft.
Total Span: 6.00 ft.
Quantity (N): 4
Live Load: 0 plf
Dead Load: 200 plf
Selfweight: 28.7 lbs
Dist. Selfweight: 4.99 plf
Total Weight: 29.9 lbs
Beam Design 2022A89
2/22/2022 1
d = 3.500 in.
A = 1.500 x 3.500 = 5.25 in.2
Beam Design 2022A89
2/22/2022 2
Volumetotal = N[A x (L + lb)] = 4 x [5.25 x (69.00 + 3)] x (12 in./ft.)3 = 0.88 ft3
Volumespan = N[A x L] = 4 x [5.25 x 69.00] x (12 in./ft.)3 = 0.84 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.88 = 29.9 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.84 = 28.7 lbs
Distributed Self Weight (ws) = = 4.99 plf
0 plf
200 plf
ws = 4.99 plf
5.75 ft.
5.50 ft.
614.96 lbs
614.96 lbs
Beam Design 2022A89
2/22/2022 3
Fbx' = (900)(0.9)(1)(1)(1)(1.5)(1)(1) = 1215.0 psi
fb = = 829.9 psi
 fb = 829.9 psi < Fbx' = 1215.0 psi  (CSI = 0.68)   ➜  OK
Beam Design 2022A89
2/22/2022 4
fv* = = 37.83 psi
 fv* = 37.83 psi < Fvx' = 162.00 psi  (CSI = 0.23)   ➜  OK
fv = = 42.10 psi
 fv = 42.10 psi < Fvx' = 162.00 psi  (CSI = 0.26)   ➜  OK
Beam Design 2022A89
2/22/2022 5
ΔLL = = 0.00 in.
(L/d)LL = 69.00 / 0.00 = ∞
ΔTL = = 0.15 in.
(L/d)TL = 69.00 / 0.15 = 469
 ΔTL = 0.15 in = L/469 < L/240   ➜  OK
fc⊥ = = 34.2 psi
 fc⊥ = 34.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.05)   ➜  OK
Beam Design 2022A89
2/22/2022 6
