Beam Design - Jannsen Garage
Size: 5.5 x 13.5
Design Span (L): 18.25 ft.
Clear Span: 18.00 ft.
Total Span: 18.50 ft.
Live Load: 479 plf
Dead Load: 200 plf
Selfweight: 317.7 lbs
Dist. Selfweight: 17.41 plf
Total Weight: 322.1 lbs
CL Beam Stability Factor 0.959 - - - - -
CV Volume Factor 0.995b - - - - -
Beam Design 2022-01
2/18/2022 1
d = 13.500 in.
Beam Design 2022-01
2/18/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [74.25 x (219.00 + 3)] x (12 in./ft.)3 = 9.54 ft3
Volumespan = N[A x L] = 1 x [74.25 x 219.00] x (12 in./ft.)3 = 9.41 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 9.54 = 322.1 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 9.41 = 317.7 lbs
479 plf
200 plf
  ws = 17.41 plf
18.25 ft.
18.00 ft.
18.50 ft.
6441.78 lbs
6441.78 lbs
Beam Design 2022-01
2/18/2022 3
lu = Unbraced Length = 18.250 ft.
lu/d = = 16.22
le = 1.63lu + 3d = 1.63(219.0) + 3(13.5) = 397.47 in. = 33.12 ft.  (NDS Table 3.3.3)
Rb = = 13.32
 Rb = 13.32 < 50   ➜  OK
Beam Design 2022-01
2/18/2022 4
FbE = = 5750.26 psi
CL =   = 0.959
CV = = 0.995
CL = 0.959 < CV = 0.995
Fbx' = (2400)(1.15)(1)(1)(0.959) = 2647.1 psi
fb = = 2082.6 psi
 fb = 2082.6 psi < Fbx' = 2647.1 psi  (CSI = 0.79)   ➜  OK
fv* = = 112.55 psi
Beam Design 2022-01
2/18/2022 5
 fv* = 112.55 psi < Fvx' = 304.75 psi  (CSI = 0.37)   ➜  OK
fv = = 128.38 psi
 fv = 128.38 psi < Fvx' = 304.75 psi  (CSI = 0.42)   ➜  OK
ΔLL = = 0.59 in.
(L/d)LL = 219.00 / 0.59 = 372
 ΔLL = 0.59 in = L/372 < L/360   ➜  OK
ΔTL = = 0.86 in.
(L/d)TL = 219.00 / 0.86 = 256
 ΔTL = 0.86 in = L/256 < L/240   ➜  OK
Beam Design 2022-01
2/18/2022 6
fc⊥ = = 390.4 psi
 fc⊥ = 390.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.60)   ➜  OK
Beam Design 2022-01
2/18/2022 7
