Grade: SP No.1
Design Span (L): 15.54 ft.
Clear Span: 15.08 ft.
Total Span: 16.00 ft.
Bearing (lb): 5.5 in.
Live Load: 575 lbs
Dead Load: 200 lbs
Selfweight: 111.8 lbs
Dist. Selfweight: 7.19 plf
Total Weight: 115.1 lbs
Beam Design 2022A86
2/18/2022 1
Beam Design 2022A86
2/18/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (186.50 + 5.5)] x (12 in./ft.)3 = 3.08 ft3
Volumespan = N[A x L] = 2 x [13.88 x 186.50] x (12 in./ft.)3 = 3.00 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 3.08 = 115.1 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 3.00 = 111.8 lbs
575 lbs
200 lbs
ws = 7.19 plf
15.54 ft.
15.08 ft.
445.05 lbs
445.05 lbs
Beam Design 2022A86
2/18/2022 3
Fbx' = (1050)(1.15)(1)(1)(1)(1)(1)(1) = 1207.5 psi
fb = = 905.6 psi
 fb = 905.6 psi < Fbx' = 1207.5 psi  (CSI = 0.75)   ➜  OK
Beam Design 2022A86
2/18/2022 4
fv* = = 23.67 psi
 fv* = 23.67 psi < Fvx' = 201.25 psi  (CSI = 0.12)   ➜  OK
fv = = 23.97 psi
 fv = 23.97 psi < Fvx' = 201.25 psi  (CSI = 0.12)   ➜  OK
Beam Design 2022A86
2/18/2022 5
ΔLL =   =   = 0.25 in.
(L/d)LL = 186.50 / 0.25 = 760
 ΔLL = 0.25 in = L/760 < L/360   ➜  OK
ΔTL =   =   = 0.36 in.
(L/d)TL = 186.50 / 0.36 = 517
 ΔTL = 0.36 in = L/517 < L/240   ➜  OK
fc⊥ = = 27.0 psi
 fc⊥ = 27.0 psi < Fc⊥x' = 565.00 psi  (CSI = 0.05)   ➜  OK
Beam Design 2022A86
2/18/2022 6
