Beam Design - AF House Remodel
Size: 5.125 x 28.5
Design Span (L): 25.50 ft.
Clear Span: 25.00 ft.
Total Span: 26.00 ft.
Live Load: 650 plf
Dead Load: 150 plf
Selfweight: 873.2 lbs
Dist. Selfweight: 34.24 plf
Total Weight: 890.4 lbs
CV Volume Factor 0.900b - - - - -
Beam Design P22000
2/15/2022 1
b = 5.125 in.
d = 28.500 in.
A = 5.125 x 28.500 = 146.06 in.2
Sx = (5.125)(28.500)2/6 = 693.80 in.3
Sy = (5.125)2(28.500)/6 = 124.76 in.3
Ix = (5.125)(28.500)3/12 = 9886.61 in.4
Iy = (5.125)3(28.500)/12 = 319.70 in.4
Beam Design P22000
2/15/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [146.06 x (306.00 + 6)] x (12 in./ft.)3 = 26.37 ft3
Volumespan = N[A x L] = 1 x [146.06 x 306.00] x (12 in./ft.)3 = 25.87 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 26.37 = 890.4 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 25.87 = 873.2 lbs
Distributed Self Weight (ws) = = 34.24 plf
650 plf
150 plf
  ws = 34.24 plf
25.50 ft.
25.00 ft.
26.00 ft.
10845.18 lbs
10845.18 lbs
Beam Design P22000
2/15/2022 3
CV = = 0.900
CV = 0.900 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.900) = 2482.6 psi
fb = = 1172.8 psi
 fb = 1172.8 psi < Fbx' = 2482.6 psi  (CSI = 0.47)   ➜  OK
Beam Design P22000
2/15/2022 4
fv* = = 88.89 psi
 fv* = 88.89 psi < Fvx' = 304.75 psi  (CSI = 0.29)   ➜  OK
fv = = 109.23 psi
 fv = 109.23 psi < Fvx' = 304.75 psi  (CSI = 0.36)   ➜  OK
Beam Design P22000
2/15/2022 5
ΔLL = = 0.35 in.
(L/d)LL = 306.00 / 0.35 = 881
 ΔLL = 0.35 in = L/881 < L/180   ➜  OK
ΔTL = = 0.45 in.
(L/d)TL = 306.00 / 0.45 = 686
 ΔTL = 0.45 in = L/686 < L/120   ➜  OK
Ab = b x lb = 5.125 x 6 = 30.75 in2
fc⊥ = = 352.7 psi
 fc⊥ = 352.7 psi < Fc⊥x' = 650.00 psi  (CSI = 0.54)   ➜  OK
Beam Design P22000
2/15/2022 6
