Beam Design - Covered Porch Edge
Design Span (L): 8.38 ft.
Clear Span: 8.25 ft.
Total Span: 8.50 ft.
Bearing (lb): 1.5 in.
Live Load: 110 plf
Dead Load: 125 plf
Selfweight: 62.3 lbs
Dist. Selfweight: 7.44 plf
Total Weight: 63.2 lbs
Defl. Limits: 480|360
Notes: Roof LL
Beam Design Dale Hansen 850 Edmondson Road, Monroe, GA 30656 2022A799
12/31/2022 1
12/31/2022 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (100.50 + 1.5)] x (12 in./ft.)3 = 1.64 ft3
Volumespan = N[A x L] = 2 x [13.88 x 100.50] x (12 in./ft.)3 = 1.61 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 1.64 = 63.2 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 1.61 = 62.3 lbs
Distributed Self Weight (ws) = = 7.44 plf
110 plf
125 plf
ws = 7.44 plf
8.38 ft.
8.25 ft.
8.50 ft.
1030.35 lbs
1030.35 lbs
12/31/2022 3
Fbx' = (800)(1.00)(1)(1)(1)(1)(1)(1) = 800.0 psi
fb = = 596.2 psi
 fb = 596.2 psi < Fbx' = 800.0 psi  (CSI = 0.75)   ➜  OK
12/31/2022 4
fv* = = 44.77 psi
 fv* = 44.77 psi < Fvx' = 169.75 psi  (CSI = 0.26)   ➜  OK
fv = = 54.88 psi
 fv = 54.88 psi < Fvx' = 169.75 psi  (CSI = 0.32)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
12/31/2022 5
ΔLL = = 0.05 in.
(L/d)LL = 100.50 / 0.05 = 2058
 ΔLL = 0.05 in = L/2058 < L/480   ➜  OK
ΔTL = = 0.11 in.
(L/d)TL = 100.50 / 0.11 = 934
 ΔTL = 0.11 in = L/934 < L/360   ➜  OK
fc⊥ = = 229.0 psi
 fc⊥ = 229.0 psi < Fc⊥x' = 378.55 psi  (CSI = 0.60)   ➜  OK
12/31/2022 6
