Grade: 24F-V3 1.8E SP/SP
Size: 5 x 9.625
Design Span (L): 8.50 ft.
Clear Span: 8.25 ft.
Total Span: 8.75 ft.
Live Load: 690 plf
Dead Load: 135 plf
Selfweight: 109.6 lbs
Dist. Selfweight: 12.89 plf
Total Weight: 112.8 lbs
Defl. Limits: 480|360
Notes: LL
Beam Design 2022A797
12/28/2022 1
b = 5.000 in.
d = 9.625 in.
A = 5.000 x 9.625 = 48.13 in.2
Sx = (5.000)(9.625)2/6 = 77.20 in.3
Sy = (5.000)2(9.625)/6 = 40.10 in.3
Ix = (5.000)(9.625)3/12 = 371.53 in.4
Iy = (5.000)3(9.625)/12 = 100.26 in.4
12/28/2022 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [48.13 x (102.00 + 3)] x (12 in./ft.)3 = 2.92 ft3
Volumespan = N[A x L] = 1 x [48.13 x 102.00] x (12 in./ft.)3 = 2.84 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 2.92 = 112.8 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 2.84 = 109.6 lbs
Distributed Self Weight (ws) = = 12.89 plf
690 plf
135 plf
  ws = 12.89 plf
8.50 ft.
8.25 ft.
8.75 ft.
3665.79 lbs
3665.79 lbs
12/28/2022 3
Fbx' = (2400)(1.00)(0.8)(1)(1.0) = 1920.0 psi
fb = = 1176.2 psi
 fb = 1176.2 psi < Fbx' = 1920.0 psi  (CSI = 0.61)   ➜  OK
12/28/2022 4
Fvx' = (300)(1.00)(0.875)(1) = 262.50 psi
fv* = = 90.05 psi
 fv* = 90.05 psi < Fvx' = 262.50 psi  (CSI = 0.34)   ➜  OK
fv = = 110.99 psi
 fv = 110.99 psi < Fvx' = 262.50 psi  (CSI = 0.42)   ➜  OK
LL Allowable: L/480
TL Allowable: L/360
12/28/2022 5
ΔLL = = 0.15 in.
(L/d)LL = 102.00 / 0.15 = 701
 ΔLL = 0.15 in = L/701 < L/480   ➜  OK
ΔTL = = 0.18 in.
(L/d)TL = 102.00 / 0.18 = 577
 ΔTL = 0.18 in = L/577 < L/360   ➜  OK
Fc⊥x' = (740)(0.53)(1) = 392.20 psi
Ab = b x lb = 5 x 3 = 15.00 in2
fc⊥ = = 244.4 psi
 fc⊥ = 244.4 psi < Fc⊥x' = 392.20 psi  (CSI = 0.62)   ➜  OK
12/28/2022 6
