Grade: 24F-V3 1.8E SP/SP
Size: 3.5 x 9.625
Design Span (L): 8.44 ft.
Clear Span: 8.13 ft.
Total Span: 8.75 ft.
Bearing (lb): 3.75 in.
Live Load: 690 plf
Dead Load: 135 plf
Selfweight: 72.8 lbs
Dist. Selfweight: 8.63 plf
Total Weight: 75.5 lbs
Notes: LL
Beam Design 2022A795
12/28/2022 1
d = 9.625 in.
A = 3.500 x 9.625 = 33.69 in.2
Sx = (3.500)(9.625)2/6 = 54.04 in.3
Sy = (3.500)2(9.625)/6 = 19.65 in.3
Ix = (3.500)(9.625)3/12 = 260.07 in.4
Iy = (3.500)3(9.625)/12 = 34.39 in.4
12/28/2022 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [33.69 x (101.26 + 3.75)] x (12 in./ft.)3 = 2.05 ft3
Volumespan = N[A x L] = 1 x [33.69 x 101.26] x (12 in./ft.)3 = 1.97 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 2.05 = 75.5 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 1.97 = 72.8 lbs
Distributed Self Weight (ws) = = 8.63 plf
690 plf
135 plf
  ws = 8.63 plf
8.44 ft.
8.13 ft.
8.75 ft.
3647.34 lbs
3647.34 lbs
12/28/2022 3
fb = = 1647.5 psi
 fb = 1647.5 psi < Fbx' = 2760.0 psi  (CSI = 0.60)   ➜  OK
12/28/2022 4
fv* = = 126.83 psi
 fv* = 126.83 psi < Fvx' = 345.00 psi  (CSI = 0.37)   ➜  OK
fv = = 156.60 psi
 fv = 156.60 psi < Fvx' = 345.00 psi  (CSI = 0.45)   ➜  OK
12/28/2022 5
ΔLL = = 0.17 in.
(L/d)LL = 101.26 / 0.17 = 602
 ΔLL = 0.17 in = L/602 < L/180   ➜  OK
ΔTL = = 0.20 in.
(L/d)TL = 101.26 / 0.20 = 499
 ΔTL = 0.20 in = L/499 < L/120   ➜  OK
Ab = b x lb = 3.5 x 3.75 = 13.13 in2
fc⊥ = = 277.9 psi
 fc⊥ = 277.9 psi < Fc⊥x' = 740.00 psi  (CSI = 0.38)   ➜  OK
12/28/2022 6
