Size: 5.5 x 16.5
Design Span (L): 23.75 ft.
Clear Span: 23.50 ft.
Total Span: 24.00 ft.
Live Load: 240 plf
Dead Load: 240 plf
Selfweight: 505.3 lbs
Dist. Selfweight: 21.28 plf
Total Weight: 510.6 lbs
CV Volume Factor 0.950b - - - - -
Beam Design 2022A791
12/26/2022 1
d = 16.500 in.
12/26/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [90.75 x (285.00 + 3)] x (12 in./ft.)3 = 15.13 ft3
Volumespan = N[A x L] = 1 x [90.75 x 285.00] x (12 in./ft.)3 = 14.97 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 15.13 = 510.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 14.97 = 505.3 lbs
240 plf
240 plf
  ws = 21.28 plf
23.75 ft.
23.50 ft.
24.00 ft.
6015.32 lbs
6015.32 lbs
12/26/2022 3
CV = = 0.950
CV = 0.950 < CL = 1
Fbx' = (2400)(1.00)(1)(1)(0.950) = 2280.2 psi
fb = = 1699.5 psi
 fb = 1699.5 psi < Fbx' = 2280.2 psi  (CSI = 0.75)   ➜  OK
12/26/2022 4
fv* = = 87.00 psi
 fv* = 87.00 psi < Fvx' = 265.00 psi  (CSI = 0.33)   ➜  OK
fv = = 98.39 psi
 fv = 98.39 psi < Fvx' = 265.00 psi  (CSI = 0.37)   ➜  OK
12/26/2022 5
ΔLL = = 0.46 in.
(L/d)LL = 285.00 / 0.46 = 615
 ΔLL = 0.46 in = L/615 < L/360   ➜  OK
ΔTL = = 0.97 in.
(L/d)TL = 285.00 / 0.97 = 294
 ΔTL = 0.97 in = L/294 < L/240   ➜  OK
fc⊥ = = 364.6 psi
 fc⊥ = 364.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.56)   ➜  OK
12/26/2022 6
