Size: 3.5 x 13.5
Design Span (L): 16.30 ft.
Clear Span: 15.80 ft.
Total Span: 16.80 ft.
Live Load: 414 plf
Dead Load: 103 plf
Selfweight: 180.6 lbs
Dist. Selfweight: 11.08 plf
Total Weight: 186.1 lbs
CL Beam Stability Factor 0.787 - - - - -
Beam Design Rachel Slack SE Walta Vista
2/11/2022 1
d = 13.500 in.
A = 3.500 x 13.500 = 47.25 in.2
Sx = (3.500)(13.500)2/6 = 106.31 in.3
Sy = (3.500)2(13.500)/6 = 27.56 in.3
Ix = (3.500)(13.500)3/12 = 717.61 in.4
Iy = (3.500)3(13.500)/12 = 48.23 in.4
2/11/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [47.25 x (195.60 + 6)] x (12 in./ft.)3 = 5.51 ft3
Volumespan = N[A x L] = 1 x [47.25 x 195.60] x (12 in./ft.)3 = 5.35 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.51 = 186.1 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 5.35 = 180.6 lbs
Distributed Self Weight (ws) = = 11.08 plf
414 plf
103 plf
  ws = 11.08 plf
16.30 ft.
15.80 ft.
16.80 ft.
4435.85 lbs
4435.85 lbs
2/11/2022 3
lu = Unbraced Length = 16.300 ft.
lu/d = = 14.49
le = 1.63lu + 3d = 1.63(195.6) + 3(13.5) = 359.33 in. = 29.94 ft.  (NDS Table 3.3.3)
Rb = = 19.90
 Rb = 19.90 < 50   ➜  OK
2/11/2022 4
FbE = = 2575.80 psi
CL =   = 0.787
CL = 0.787 < CV = 1.0
Fbx' = (2400)(1.15)(1)(1)(0.787) = 2173.3 psi
fb = = 1979.6 psi
 fb = 1979.6 psi < Fbx' = 2173.3 psi  (CSI = 0.91)   ➜  OK
fv* = = 117.77 psi
2/11/2022 5
 fv* = 117.77 psi < Fvx' = 304.75 psi  (CSI = 0.39)   ➜  OK
fv = = 136.63 psi
 fv = 136.63 psi < Fvx' = 304.75 psi  (CSI = 0.45)   ➜  OK
ΔLL = = 0.51 in.
(L/d)LL = 195.60 / 0.51 = 384
 ΔLL = 0.51 in = L/384 < L/360   ➜  OK
ΔTL = = 0.65 in.
(L/d)TL = 195.60 / 0.65 = 301
 ΔTL = 0.65 in = L/301 < L/240   ➜  OK
2/11/2022 6
fc⊥ = = 211.2 psi
 fc⊥ = 211.2 psi < Fc⊥x' = 650.00 psi  (CSI = 0.32)   ➜  OK
2/11/2022 7
